Author Topic: Using high speed transducer  (Read 10230 times)
Offline Bryson
  • Unit(s): 998c
« on: July 05, 2014, 10:24:36 AM »
Hi, am new to this, I just bought 998c, I also got the transom highe speed transducer to hook with sidby cable with si.
My question is what to choose in the transducer setup section, do I keep it on HD sideimging , do I have to switch the setup when you go fast. , or dose the head unit use that as the main 2d transducer as soon as you hook it up?
Offline mako9man2
  • Unit(s): 999ci HD SI
Re: Using high speed transducer
« Reply #1 on: July 05, 2014, 03:29:02 PM »
You don't have too do anything.  The Y cable eliminates the input from the built in 2D transducer in the large SI transducer and imports the signal from the stand alone 2D.
Offline Trout Bum
  • Unit(s): 958 HD, 788 ci HD
  • Software: 6.640
  • Accessories: aux speed & temp, ethernet
« Reply #2 on: July 05, 2014, 06:41:00 PM »
After the initial hookup just make sure that the High Def Side Scan transducer is selected in the Sonar menu and you will be good to go. The unit will get all the SI and DI from the HDSI ducer and all the 2D sonar from the 2D ducer. It's a no brainer!
2013 Lund Rebel 1650 XL Sport
60 hp Mercury 4-stroke
Humminbird 998c HD SI, 958c HD & 788ci HD
Minn Kota Terrova w/i-pilot
by Bryson
by Doc Stressor
Last post July 17, 2014, 03:12:14 PM
Last post June 20, 2015, 11:33:01 AM
by starkyb
Last post September 02, 2016, 08:45:33 AM
Last post July 05, 2017, 12:05:04 AM
Last post March 31, 2017, 04:24:54 AM
by Terrible45
