Author Topic: High Speed 2D transducer  (Read 15513 times)
Offline ETnSC
  • Unit(s): 1197c SI
  • Software: 5.43
« on: May 13, 2010, 12:48:32 PM »
OK, I know I have seen on the forum somewhere the Humminbird model number for a 2D high speed transom mount transducer.  After 30 minutes of searching and reading posts, I give up.  Would someone be kind enough to give the model number I need.  It will be used with an 1197c SI, I do not want a quadbeam, and I know I need a Y cable.
For some reason I am search impaired today.
Thanks,
ED
ET
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: High Speed 2D transducer
« Reply #1 on: May 13, 2010, 02:07:51 PM »
Ed,
you talking about this?
http://store.humminbird.com/products/314026/XNT_9_20
Hope it's the one you mean.
Regards /Harry
YES,......
WE SCAN!
Offline ETnSC
  • Unit(s): 1197c SI
  • Software: 5.43
« Reply #2 on: May 13, 2010, 02:13:37 PM »
I saw that one on the Humminbird site but was not sure it would work since the 1197c SI was not list under the compatible models.  I knew there were transducers that would work and not listed but was not sure which ones.  Figured I would ask and be safe.  Thanks.
ET
« Reply #3 on: May 13, 2010, 02:58:09 PM »
The XNT-9-20 would be if you want to mount the 2D transducer on the outside of the hull.  For an inside-the-hull mount you should go with the XP-9-20 transducer.
 Both need the AS-Si-DB-Y cable
Offline Jolly Roger
  • HB Addicted
« Reply #4 on: May 13, 2010, 03:21:03 PM »
Anytime Ed,
I figure the units listed with the transducers are the ones which primarily use these transducers.
Since the XNT-9-20 and the XP-9-20 both use the same 2D frequencies (83/200 kHz) like the 1197 HDSI transducer and the connectors are the same they will work on SI units in combination with the Y-cable or the transducer switch.
Regards / Harry
« Last Edit: May 13, 2010, 03:24:12 PM by Jolly Roger »
YES,......
WE SCAN!
Offline Bryson
  • Unit(s): 998c
« Reply #5 on: July 05, 2014, 11:05:56 AM »
Yes I have the XNT 9 20 T, I think it has the temp sensor which I figured out that I don't need it, but I have it now
by Doc Stressor
by jgcox6
Last post January 03, 2014, 02:59:58 PM
by louisd33
Last post July 05, 2014, 06:41:00 PM
by Trout Bum
Last post June 20, 2015, 11:33:01 AM
by starkyb
Last post September 02, 2016, 08:45:33 AM
Last post July 05, 2017, 12:05:04 AM
