Author Topic: Humminbird PC not compatible with Windows 8?  (Read 24115 times)
Offline coreyc
  • Unit(s): 998C 958C
« on: April 29, 2013, 08:33:39 PM »
I downloaded it, but when I try and open it, it just goes to install again.  Asks if I want to repair or delete.  Any help is appreciated, I only have macs and windows 8 and can't get it to work on either.
Offline erocks4u
  • Unit(s): 1198 c si / 1198 c si
  • Software: 6.420
  • Accessories: Weather sense , gps , Ipilot
Re: Humminbird PC not compatible with Windows 8?
« Reply #1 on: April 29, 2013, 11:58:29 PM »
I'm running windows 8 and it works for me, using version 4.3.8. sounds like your clicking on the install file instead of the program file. are you clicking the bird in the start/metro screen?
don't take my post the wrong way, just trying to help.
Al
« Reply #2 on: April 30, 2013, 12:31:14 AM »
It does sound like you're clicking the .exe installer again...
It probably did not install a Shortcut start button on the desktop...
Try ...Start/All Programs/Humminbird/Humminbird PC...
Offline coreyc
« Reply #3 on: April 30, 2013, 12:34:27 AM »
Got it figured out, thanks!  One thing, on my 958 while having gps on any screen I get COG readout instead of temp, is anyone else getting this?
« Reply #4 on: April 30, 2013, 01:02:49 AM »
The COG reading is hard coded into any map view...(even tho you can change it in the Menu system it will not change on the map view)...
HB decided you must have COG any time you are viewing a map...
You can change the COG readout on any "non-map" view...
« Last Edit: April 30, 2013, 01:04:53 AM by rnvinc »
Offline coreyc
« Reply #5 on: April 30, 2013, 01:06:15 AM »
What does COG stand for?
« Reply #6 on: April 30, 2013, 01:10:21 AM »
COG is "Course Over Ground" which is the direction of travel....measured in a 360° circle with North being 0/360°....
HB decided you should see your "direction of travel" (in degrees from North) when you are looking at a map...
« Reply #7 on: April 30, 2013, 01:12:54 AM »
"BIG WATER" guys need COG because they may not be able to see land...
Last post July 13, 2011, 03:02:43 PM
by erhan
Last post March 02, 2012, 12:13:48 PM
by Roddy
Last post August 19, 2013, 04:39:05 PM
by bflipn
Last post January 29, 2015, 02:59:11 PM
Last post August 11, 2015, 06:21:58 PM
by lancepeterson
Last post February 23, 2023, 09:39:44 AM
by DickeyMcD
Last post November 17, 2019, 11:08:34 AM
by crankin007
Last post April 18, 2022, 08:42:08 AM
by FuzzyGrub
