Author Topic: 798c SI as Chartplotter only  (Read 10595 times)
Offline dvanpham
  • Unit(s): 798ci SI and 998c SI
  • Software: 6.180
  • Accessories: Interlink, DrDepth
« on: March 06, 2011, 12:36:52 AM »
Hi everyone,
If I wanted to use my 798c SI as a chartplotter only, will I be doing any damage to my unit by running it in Normal Mode without a transducer attached to it?  Can I just turn Sonar off under the settings and be fine?
Thanks in advance for your help.
« Last Edit: March 06, 2011, 01:05:41 AM by dvanpham »
Re: 798c SI as Chartplotter only
« Reply #1 on: March 06, 2011, 10:44:11 AM »
Yes, you can turn off the sonar.  Yes you can run without the transducer attached.
However a caution is in order. If you have the extention cable plugged into the unit do not power on without the transducer attached. It can burn the transmitter if you have sonar on.
Offline dvanpham
  • Software: 6.180
« Reply #2 on: March 06, 2011, 02:13:45 PM »
Thanks, Sonar2000.  The only thing I have connected to it is power.  Would there any issues if I forget to turn off sonar if there is no transducer or extension cable connected to it?
« Reply #3 on: March 06, 2011, 02:36:18 PM »
I see no problem with that.  The only issue is with an extender cable and no transducer... but you seem to not have the extender so you should be fine..
Always ask questions here any time.
Offline dvanpham
  • Software: 6.180
« Reply #4 on: March 06, 2011, 02:53:47 PM »
Thanks again!  If there's going to be problem with doing something, I'd much rather know now than after I break it!   :)
« Reply #5 on: March 06, 2011, 04:28:15 PM »
Exactly...... ::)
chuck
Last post February 21, 2010, 09:24:13 PM
by diver651
Last post October 02, 2014, 06:43:18 PM
Last post April 11, 2016, 10:50:14 PM
Last post February 23, 2017, 08:05:05 PM
Last post August 19, 2020, 06:34:58 PM
Last post July 29, 2021, 12:44:05 PM
by nediver
Last post August 19, 2024, 08:24:24 PM
by BertP
