Author Topic: 1197-Chartplotter window scale keeps changing on me  (Read 16193 times)
Offline nediver
« on: July 16, 2021, 04:46:04 PM »
Hi All,
Once I enter  Lat/Lon of a target I want to dive and drive the boat towards it I generally set the chartplotter window scale to view where I am to say, 1,000 feet. As I get closer to the target I drill down for an expanded view to say 500 feet, then 100 feet then 20 feet etc..
For the past month or so I'll have it set at say 100 feet and all by itself perhaps a minute later it moves to 500 feet. It is doing this all the time.
I did the 2 re-format moves and that did not solve the problem.
Any help appreciated.
Re: 1197-Chartplotter window scale keeps changing on me
« Reply #1 on: July 16, 2021, 08:57:09 PM »
Have you tried Restore Defaults ??
Offline nediver
« Reply #2 on: July 17, 2021, 08:01:16 AM »
Yes and I did and "Format Nav Directory" also.
« Reply #3 on: July 17, 2021, 08:57:58 PM »
If you are using a map card try the scenario with no map card just using the basemap  ...
Offline nediver
« Reply #4 on: July 17, 2021, 09:56:54 PM »
Great idea thank you. Will do.
It it stops doing it while my Navionics chip is out-what does that tell me/us?
« Reply #5 on: July 18, 2021, 09:30:29 PM »
A corrupted map card can cause weird gremlins  ...
If the issue goes away with no map card - contact Navionics  ...
https://www.navionics.com/usa/support/contact-us
Offline nediver
« Reply #6 on: July 22, 2021, 03:38:29 PM »
I got out today and pulled the Navionics card out.
Machine did the same thing-no change at all-range setting changes all the time.
Any other ideas appreciated.
« Reply #7 on: July 22, 2021, 09:25:13 PM »
Under the Setup tab set User Mode to Advanced  ...
Then look under the Chart tab for Auto Zoom and Auto Range. Make sure both are Off
Offline nediver
« Reply #8 on: July 29, 2021, 12:44:05 PM »
Yes! I followed the advice above and changed the setting but it didn't work.
I then read another post that I  should do both of these: Change AUTO ZOOM setting AND change AUTO RANGE settings and it worked. Was out for 4 hours yesterday and the Bird worked great-no issues.
Thank you everyone I really appreciate your help!
HH
Last post February 21, 2010, 09:24:13 PM
by diver651
Last post March 25, 2010, 06:18:12 PM
by Rickard
Last post June 02, 2010, 07:37:31 PM
by dpirila
Last post March 06, 2011, 04:28:15 PM
Last post March 10, 2014, 10:28:39 PM
by scattman
Last post August 02, 2016, 10:49:52 PM
Last post January 01, 2019, 08:18:11 PM
by Sodaksam
Last post August 19, 2020, 06:34:58 PM
