Author Topic: humminbird 798c si nvb  (Read 19751 times)
Offline pistol1979
  • love bass fishing
  • Unit(s): 798 c si nvb
  • Software: 6.4
« on: September 21, 2014, 11:32:11 AM »
Hello everyone i just bought my 798 used with 27 hours on it after installation the charts wont load and says gps not connected so i put my head on my buddies boat and everything worked so figured it was the receiver so orderd a new one put it on and still no maps and gps not connected will i need to put it in the water for it to start working or could there be something else. Thanks for any help
Re: humminbird 798c si nvb
« Reply #1 on: September 21, 2014, 12:20:59 PM »
Sometimes it takes several minutes for the antenna to acquire the satillites ...(you will get no chart views until it does)...
Make sure the antenna has a good sight of the sky...and give the unit 5-10 minutes to see if it will connect... (this usually takes less than 2...even on 1st power up)...
_______________
A common issue with the quick attach bases is a possible bad connection...
You might think about taking the cables out of the base and plug them directly into the unit for testing...
One other test would be to put your buddy's unit on your antenna for testing ...
« Last Edit: September 21, 2014, 12:24:18 PM by rnvinc »
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #2 on: September 21, 2014, 09:23:05 PM »
One more thing, I now have a steel roof on house and garage - OMG!
I have a heck of a time getting a signal lock - the HS GPS puck is close enough to one overhead door if I get Sat's in the right places - I get a lock, in a garage I wouldn't expect it to lock so I though I would toss that out there...
I had to pull the boat out half way for my i-Pilot to lock after I found it's beeper quit, and I was afraid I was going to have to use that STUPID pedal!!
My 798 can't see a thing in the garage..... :'(
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #3 on: September 21, 2014, 09:30:38 PM »
Thanks for the help i finally figured it out. After trying everything i decided to update the software i from 5.8 to the 6.4 and bam the gps connected.so that part is fixed but 1 more issue i am having and have not got to test after the update is after about 30 minutes of scanning with the side imaging the right side starts getting blank spots in it then after a bit longer it will completely quit working do you think the update will fix that to or what im thinking is a bad transducer...thanks for the replies
Offline sfw1960
« Reply #4 on: September 21, 2014, 09:39:03 PM »
It does sound like a possible XDCR...
I would suggest you do a complete reset like you did before the update, and FWIW - a reset after can clear up some bugs....
G'Luck!
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #5 on: September 21, 2014, 09:42:20 PM »
What is a xdcr sorry im new to this lol...
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #6 on: September 21, 2014, 09:48:36 PM »
Nevermind dumb ? I get it now
Offline sfw1960
« Reply #7 on: September 21, 2014, 10:13:50 PM »
TRANSDUCER.... there!
Ya made me spell it out - but just this ONCE for you!! lol   >:D
« Reply #8 on: September 22, 2014, 12:48:07 PM »
pistol1979,
Let me guess: you bought the AS-GRP GPS Receiver, didn’t you?  It requires the 6.300 or higher software to work with the older units like the 798’s.
For the right Si sonar blank spot issue: try swapping units with your buddy again to see if the problem stays with the 798 unit or stays with your boat.  That will help pinpoint where the problem is.
[I also sometimes abbreviate transducer as just “Xd”.]
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #9 on: September 22, 2014, 01:54:22 PM »
Thats interesting if thats the case then the guy i bought it from lied because when i got the unit in the mail it came with the as grp puck and he said it was a working unit. So thats when i orderd a new puck and it would not work either so then i updated
« Reply #10 on: September 22, 2014, 02:06:13 PM »
Maybe he tested the 798 with another GPS Receiver and tested that GRP on another unit?  That should be the only way they both would have worked.
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #11 on: September 25, 2014, 01:56:29 PM »
Finally got to take my boat out and everything worked great. So it was a software version problem. Thanks for all the replies. See yall all soon with some pics.....
Offline sfw1960
« Reply #12 on: September 25, 2014, 07:51:38 PM »
We like PIX!!!!!!!!!!!    ;D
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #13 on: October 02, 2014, 04:35:59 PM »
Just wanted to update. Thought it was fixed but my right side went out again so my buddy put it on his boat and used it all day with no problems so time to buy a new XDCR is the XNT 9 Si 180 T the only one that will work or is there a better option... Thanks....
Offline sfw1960
« Reply #14 on: October 02, 2014, 05:39:34 PM »
You can use the HDSI xdcr on that but MSRP is $269 and can be found for just under $200 smackers.
http://www.universalmania.com/humminbird-xhs-9-hdsi-180t-tm-transducer/
It does improve the 455Khz imaging although the 798 doesn't have 800KHz capability, sharper images and is considerably larger (about 6" L.).
The Compact SI is $199 MSRP - and can be had for less also.
I do have one of the compacts sitting here, but have not given much consideration about keeping as a spare or selling as I have 3 machines, but sonar is unused on one - GPS only.
Good Luck!
Offline pistol1979
  • love bass fishing
  • Software: 6.4
« Reply #15 on: October 02, 2014, 06:02:21 PM »
Ok thanks. Is it worth the extra $$$$$
Offline sfw1960
« Reply #16 on: October 02, 2014, 06:43:18 PM »
I can't make that call for you - some folks say ABSOLUTELY YES and some say nope.
Depending on the pricing your get - it's probably $40-60 difference, and that doesn't go far now a days.
I have the HDSI on both ends of my boat and the 899ci HDSI originally comes with the compact (cSI) 455KHz XDCR.
Did I see a difference switching over - YEP and my eyes are not that good (diabetic).
For  the price difference, I myself say it's worth it. The only reason I didn't put my  cSI XDCR up for sale is in case I have a failure and I was toying with using it on the ice this winter, as my 798 serves year 'round and I run her in "dual beam"  (or US/2 for some model menus) mode thru the ice.
The DI has good target separation so I wondered if I'd like to try it.
HTH,
Last post April 07, 2016, 10:27:19 PM
by dakota
Last post September 14, 2011, 07:53:59 PM
by Shawk
Last post September 20, 2011, 02:14:28 PM
798c si
Started by dbrettle 798c SI
Last post February 06, 2013, 04:27:05 AM
by dbrettle
Last post May 16, 2013, 09:48:55 PM
by slackwater
Last post July 02, 2013, 12:17:31 PM
Last post November 15, 2013, 03:39:26 PM
by CamoHunter
