Author Topic: Electrical Connections Chartplotter to Autopilot  (Read 6582 times)
Offline JeffZ
  • Unit(s): 898c HD SI
« on: August 19, 2020, 08:30:30 AM »
I posted this here rather than in the 898c si forum because I thought some other forum member might be able to help. I am trying to get a (legacy) Raymarine S1000 Autopilot operating, and I am having trouble with the wiring configuration. The S1000 Autopilot must receive position information from a suitable GPS in order to function correctly. NMEA 0183 is suitable. Can somebody confirm that this is the correct way to wire the units using a Humminbird AS HHGPS Accessory Bare Wire GPS Connection Cable?
Hummingbird           Raymarine
Red (12v+)
Black (Ground)           Brown & Blue, Plus to Ground
Green (NMEA In)   Green
White (NMEA Out)   Orange
Should I connect the Red and black wires to the battery? To a marine terminal connector? Ground the black wire somewhere on the boat?
Here's info on the Raymarine wiring. Pin's not relevant since it looks like I have to cut off the connector to attach it to the Humminbird cable.
Wire Color   "Pin Number"   "NMEA Signal at S1000"   "Connection at 3rd Party GPS"
Brown         1                        -ve out                           NMEA -ve receive
Green         2                        +ve out                   NMEA +ve receive
Orange         3                        +ve in                           NMEA +ve transmit
Blue                 5                        -ve in                           NMEA -ve transmit
Part of the problem is that I don't understand what the "-ve" and "+ve" mean.
Appreciate any assistance.
Re: Electrical Connections Chartplotter to Autopilot
« Reply #1 on: August 19, 2020, 06:34:58 PM »
If no one pops in with info Humminbird maybe able to help  ...
1-800-633-1468
Last post February 21, 2010, 09:24:13 PM
by diver651
Last post March 06, 2011, 04:28:15 PM
Last post June 03, 2011, 11:57:52 AM
Last post March 04, 2012, 10:00:45 PM
by oz
Last post July 24, 2012, 10:54:41 AM
Last post April 01, 2016, 08:52:02 PM
by RonnieB
Last post July 29, 2021, 12:44:05 PM
by nediver
Last post August 19, 2024, 08:24:24 PM
by BertP
