Author Topic: The width of the horizontal beam  (Read 8236 times)
Offline Kimi
  • Unit(s): 798CXI 898 CXI
« on: February 28, 2011, 10:48:44 AM »
Hi folks! Just wonder how wide/narrow the horizontal SI-beam is. And (is there a) difference betwean 455 and 800 kHz.
Kimi..
homepage: ( in Finish only) www.wreckdiving.yolasite.com
Re: The width of the horizontal beam
« Reply #1 on: February 28, 2011, 03:01:19 PM »
Kimi,
Are you meaning how wide the beams are left-to-right or front-to-back?
Left—right they are:
455kHz  86 degrees
800kHz  55 degrees
Front-to-back they are both 0.5 to 1.5 degrees.  I’m not sure what the exact measurement is but they are pretty thin.
Offline Kimi
« Reply #2 on: February 28, 2011, 03:23:06 PM »
Thanks !
Those numbers are close enough!
Kimi :)
Offline Rickard
« Reply #3 on: March 01, 2011, 02:52:05 PM »
Kimi,
Edgetech has a good text on beam widths here: http://www.edgetech.com/docs/app_note_beamwidth.pdf
If the approximate formula is applied to the HDSI transducer the result is 1.5 degrees at 455 kHz and 0.9 degrees at 800 kHz. As Edgetech explains, this is the one-way -3 dB measure. Actually, the practical widths are even narrower because the beam is further slimmed when the transducer receives the echo. This two-way width is 1.1 degrees at 455 kHz and 0.6 degrees at 800 kHz.
Rickard
Offline Kimi
« Reply #4 on: March 01, 2011, 03:05:47 PM »
Thanks Rickhard!
Great information
Kimi... :D
Last post June 17, 2010, 11:30:24 PM
Last post June 12, 2011, 12:13:42 AM
by T.G
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post January 09, 2012, 08:30:31 AM
Last post December 29, 2012, 10:31:01 AM
Last post February 22, 2013, 01:19:02 PM
by Blue68Camaro
Last post April 05, 2014, 12:17:20 PM
by LittleGazoo
Last post March 10, 2018, 10:08:56 AM
