Author Topic: Trolling motor interference  (Read 14090 times)
Offline Sigler
  • Unit(s): 1198c 788ci di
  • Accessories: interlink
« on: February 26, 2011, 07:22:10 PM »
I know I am full of questions but when I first hit the trolling motor I get interference on my front graph (788ci di). The wires for the trolling motor are ran down the passanger side of the boat and the graph wires are ran down the driver side and they are not connected to the same battery. I also have the noise button set on high 3. I wish one of you guys from Humminbird was fishing with me so I could get all this stuff worked out. LOL   I also couldnt figure out why when I am going to a waypoint the water depth would bounce up and down and it seemed like the waypoint kept moving around in dfferent directions.
« Last Edit: February 26, 2011, 07:37:23 PM by Sigler »
Re: Trolling motor interference
« Reply #1 on: February 27, 2011, 08:22:46 AM »
A couple of things come to mind....
If you are navigating using the trolling motor make sure the transducer is staying in the water. If it is mounted on the bottom of the ducer it should be staying down but just check for bounce..
If you speed is lerss than .5 mph the gps may wander especially if using the older gps puck.
Also make sure the gps receiver signal is not being blocked.
Pictures of mounting will be helpful
Offline Sigler
« Reply #2 on: February 27, 2011, 10:04:41 AM »
Here are some photos I havehad a graph up there every since I have own the boat. And they have always been mounted this same way, and I have never had interference.ila_renderedila_rendered
« Reply #3 on: February 27, 2011, 09:06:44 PM »
Todd,
Give Humminbird a call, they have a TM interference kit they will send you.  Do you have common ground wires?
Offline Sigler
« Reply #4 on: February 27, 2011, 10:17:00 PM »
All I no is the trolling motor is ran to the back down the passager side and the graph is hook up to the fuse panel by the steering wheel. If I was guessing I would say there is a common ground.
« Reply #5 on: February 27, 2011, 11:07:16 PM »
Its important to isolate it completely to get rid of any interference and even then you may still get some emi.  The TM interference kit will certainly help.  I dont think they charge you!
« Reply #6 on: February 28, 2011, 03:26:28 PM »
I don’t think that they will send you the trolling motor interference kit Sigler.  This is what I have been told about RF interference on the new DI units:
“The first step is to get consumer services to send him a PC 11 with the choke built in.  Then need to make sure he has no connection between cranking and trolling motor battery.  If it is a universal sonar motor the #1 reason for interference is the fuse in the head of the motor being blown.”
Offline Sigler
« Reply #7 on: March 01, 2011, 12:34:14 AM »
I dont no were the fuse would be to check it there are breakers back at the battery. Its a 24 volt TM.
« Reply #8 on: March 03, 2011, 02:41:25 PM »
It would be in the head of the trolling motor.  Check the operations manual for your trolling motor to see if they show its location or additional info.
Last post March 30, 2013, 02:01:11 AM
by wolfs4evr
Last post April 09, 2013, 07:20:16 AM
Last post August 20, 2013, 04:08:30 PM
Last post April 14, 2014, 07:07:56 PM
by tokerwashere
Last post January 19, 2016, 11:13:53 PM
Last post June 12, 2017, 01:44:26 PM
by zip308
Last post April 15, 2019, 11:15:23 AM
by fishcall
Last post September 12, 2021, 08:18:44 PM
