Author Topic: Trolling motor interference on 598  (Read 14555 times)
Offline ericd
  • Unit(s): 798C
« on: March 24, 2013, 05:16:41 PM »
I installed a new 598 on trolling motor with the new trolling motor transducer. When I hit the trolling motor (motor guide) button my screen has some major interference. The noise filter is on. What is a solution to this problem? Thanks
Re: Trolling motor interference on 598
« Reply #1 on: March 24, 2013, 09:22:39 PM »
Read this...
http://www.humminbird.com/Faq.aspx?TaxonomyId=103A1849
Then call HB 1-800-633-1468
Offline bdeleon123
« Reply #2 on: April 08, 2013, 11:35:45 PM »
I have tried everything.
Running off cranking battery
Trolling motor wire on oneside of boat, electronics on other
grounded TM housing to TM battery negative.
Chokes for the Transducer cable and the power cable
Nothing worked.
I had a second boat pulled up beside mine, I plugged it's power source into my 597CIDI and left the sonar cable plugged in on my boat.  I also moved the transducer away from the trolling motor and put the noise cancellation on high 1.  it got rid of the problem.  the closer I moved the transducer to the trolling motor, it gradually got worse.  You have to be about a 1.5ft from the TM in order to get rid of the interference.  Once I plugged the unit into the power source on my boat, it got increasingly worse.
Here is something for you, I plugged in my 898SI into the power supply and the transducer for the 597 that was giving me problems and I did not see the interference on the 898SI.
I'm not sure what is going on but this is unacceptable.
« Reply #3 on: April 09, 2013, 07:20:16 AM »
ericd,
Call the HB Customer service.  They offer a TM Interference Kit and will try to get you rproblem resolved.
I have also posted new article on Trolling Motor Interference in the Articles and Tutorials Section that should help understand some of the issues and how to troubleshoot.
Good Luck,
« Last Edit: April 09, 2013, 07:48:29 AM by RGecy »
Last post March 18, 2011, 06:27:53 AM
by SaminVa.
Last post March 03, 2011, 02:41:25 PM
Last post January 19, 2013, 10:43:18 AM
by walleye10000
Last post June 26, 2012, 03:42:24 PM
Last post March 30, 2013, 02:01:11 AM
by wolfs4evr
Last post August 20, 2013, 04:08:30 PM
Last post June 12, 2017, 01:44:26 PM
by zip308
Last post April 15, 2019, 11:15:23 AM
by fishcall
