Author Topic: 1197 101 terrova interference when using trolling motor  (Read 11445 times)
Offline iowamuskies
  • Unit(s): 1197
  • Accessories: weathersense
« on: August 17, 2013, 02:36:01 PM »
I have a 1197 unit on the bow attached to a 101 terrova with ipilot.  After two years of working fine, I now have erratic depth and temperature readings whenever I step on the throttle to turn the prop on the trolling motor.  When I release the throttle, the depth readings go back to normal however the temp reading never recovers unless I turn the unit off and back on again.  Issue still exists if the other 1197SI I have on the console is turned off.
Any advice on how to most easily solve this issue?  Do I replace my 101?
Offline reddog
    • My pictures
  • Unit(s): 2)997 C SI, 788CI, 787C2, 1197 1198
  • Accessories: Ipilot Link
Re: 1197 101 terrova interference when using trolling motor
« Reply #1 on: August 18, 2013, 06:54:17 AM »
Has anything changed with your software version? What v are you running?
Hate to see her go, but love to watch her leave.
Offline iowamuskies
  • Unit(s): 1197
« Reply #2 on: August 18, 2013, 01:34:02 PM »
Nothing has changed on the software version.  I have not updated since new as I am a bit worried about getting into the update process and it not working and being unable to back my way out (I am on a Mac...).
« Reply #3 on: August 18, 2013, 02:27:38 PM »
Here is some info of possibilities...
http://www.bbcboards.net/humminbird-sonar-gps/172968-all-sonar-information-resource.html#post1538564
RF can come from many different sources...
It's a process of elimination to track it down...
Be patient...what works for some may not work for others...
HB can also help...1-800-633-1468
« Reply #4 on: August 20, 2013, 04:08:30 PM »
+1
Call the Humminbird Customer Resource folks: 1-800-633-1468
Last post March 18, 2011, 06:27:53 AM
by SaminVa.
Last post March 03, 2011, 02:41:25 PM
Last post January 31, 2012, 08:02:31 AM
Last post June 26, 2012, 03:42:24 PM
Last post March 30, 2013, 02:01:11 AM
by wolfs4evr
Last post April 09, 2013, 07:20:16 AM
Last post June 11, 2013, 11:28:36 AM
Last post April 01, 2020, 08:56:46 AM
