Author Topic: Depth Offset  (Read 9127 times)
Offline bobn
  • Unit(s): 997 csi
Depth Offset
« on: October 30, 2010, 07:51:50 PM »
When useing the depth offset  the digital depth readout is changed  to reflect the offset.  But will the NMEA  DPT  output sentence reflect the offset  and  if recording a .SON  file will the  200 khz  B001.SON reflect the offset?
Re: Depth Offset
« Reply #1 on: October 31, 2010, 10:00:44 PM »
Very good question.  I have never tested this.  The depth used to not be recorded in the son files and was only calcualted on playback.  An educated guess, the raw data does not reflect the depth offset when its recorded.  It records the actual depth.  The depth offset is a "post processing" feature.
I will verify this for you.  Excellent question!
Re: Depth Offset
« Reply #2 on: November 01, 2010, 08:37:30 AM »
I’ll agree with Robert that someone will have to verify this (I do not have a way to do so) but I thought that the Depth Offset menu setting did affect the NMEA DPT sentence data.  Not sure about the recorded data but would agree with Robert that the depth is recalculated when it is played back.
Offline bobn
  • Unit(s): 997 csi
Re: Depth Offset
« Reply #3 on: November 04, 2010, 10:28:20 PM »
I  took the boat out to try and answer my question ,  didn't get the result I expected.  What I found is the NMEA  output depth is the actual water depth and the 997 depth offset  had no effect , but it does change the unit digital depth readout.  Surprisingly  the depth offset  appears to effect the 200 khz beam  recording , the depth is the offset depth.   I find that hard to believe.  Unfortunately , I needed to winterize and putup the boat for the season.  Hopefully  someone  down south can take a test .
Offline bobn
  • Unit(s): 997 csi
Re: Depth Offset
« Reply #4 on: November 05, 2010, 01:04:58 PM »
The DPT NMEA sentence includes transducer depth along with the offset from the transducer to the surface.  So its up to the receiving program or device to utilize the offset.
Last post February 06, 2012, 06:28:07 PM
by stillbear
Last post April 04, 2017, 06:34:25 AM
by LGF
Last post October 11, 2013, 06:43:25 PM
by slabbacks
Last post April 09, 2014, 06:47:11 AM
by bobcoy
Last post July 01, 2014, 06:25:06 PM
Offset Speed
Started by Fay 798c SI
Last post October 25, 2014, 08:53:41 AM
by Fay
Last post August 28, 2017, 10:01:22 PM
Last post September 07, 2018, 11:15:17 AM
by jimf
