Author Topic: Odd temperature scale on overlay data  (Read 8403 times)
Offline Sodaksam
  • Unit(s): Helix 9 Mega SI G2N
« on: December 30, 2018, 06:25:12 PM »
Hello, I just bought a new Helix 9 Mega SI unit.  I've been watching videos to get it set up.  The overlay data shows the temp in my garage from 1-323 degrees t.  Yes, a lower case t.  If I put the data in the box form, it reads 22 degrees F.  As I scroll through the views about 3/4 of the views show the temp in Fahrenheit.  The others show it in t.  I'd rather not use the boxes as it takes up screen space.  Not a big deal, but anyone have some insight?   Thanks, Sam
Re: Odd temperature scale on overlay data
« Reply #1 on: December 30, 2018, 08:18:23 PM »
Any Chart view replaces Temp (xx°)  with COG (t°)  ...
COG is beneficial in showing which way the boat is navigating as compared to a 360° circle where  ...:
0/360° is due North
90° is due East
180° is due South
270° is due West
HB programmed the Chart view overlays with COG because it is common for a boater to need to know which way the boat is navigating any time the boater is using a Chart view  ...regardless if the boater can or cannot see landmarks to orient North, East, South, West  ...
« Last Edit: December 30, 2018, 08:26:43 PM by rnvinc »
Offline Sodaksam
« Reply #2 on: December 30, 2018, 11:01:38 PM »
Thanks.  So, am I stuck with this instead of temp on a few of my views?  Thanks for the help
Offline Sodaksam
« Reply #3 on: December 30, 2018, 11:27:08 PM »
The actual temp shows up in the box tho.  Switching to overlay is goes to the ‘t’ units.  Seems like something isn’t quite right.  Can I turn COG off?  I’m not real tech savvy, but this seems odd.
« Reply #4 on: December 31, 2018, 03:24:26 PM »
Overlay data cannot be replaced nor individually shut off  ...
COG in overlay is hard coded for any chart view  ...
HB feels if you are looking at a Chart view = you need to see COG  ...
« Last Edit: December 31, 2018, 03:25:34 PM by rnvinc »
Offline Sodaksam
« Reply #5 on: January 01, 2019, 08:18:11 PM »
Thanks, I was a little slow on the uptake on this.  Makes sense, finally.
Last post December 04, 2011, 09:13:45 AM
Last post March 25, 2010, 06:18:12 PM
by Rickard
Last post November 02, 2011, 10:12:45 PM
by radeleur
overlay
Started by T.G 898c SI
Last post March 03, 2012, 07:09:45 PM
by T.G
Last post March 23, 2013, 05:08:50 PM
by magan863
Last post March 10, 2014, 10:28:39 PM
by scattman
Last post May 29, 2015, 10:27:37 PM
by d.sonnenburg
Last post July 29, 2021, 12:44:05 PM
by nediver
