Author Topic: Uploading points to my unit  (Read 13622 times)
Offline Barmic
  • Regards Barmic
  • Unit(s): 798 si
« on: October 27, 2010, 06:07:47 AM »
G,day I have had my 798si for a while now and i thought it time i started getting into it a bit more, I,de like to know if its possible to create tracks/waypoints in google maps, send them to HB PC and upload them to my unit.
Just stumbled onto this forum and think its great.
Offline mendota
  • Unit(s): 1197
  • Software: 4.75
  • Accessories: AS-GRHA
Re: Uploading points to my unit
« Reply #1 on: October 27, 2010, 01:51:35 PM »
Yup, you can export from GE in the .kml format, then use GPSBabel to convert to .gpx format, which HBPC recognizes.  Beware of significant offsets to the GE photo data - you may want to import your own photo overlay into GE, which works really well if you have access to better aerial photos than GE provides.
Edit: - Oops, I read that as Google Earth, rather than Maps.  But I think my response might still be helpful.....both GE and GPSBabel are free downloads.
« Last Edit: October 27, 2010, 01:54:51 PM by mendota »
Offline Barmic
  • Regards Barmic
  • Unit(s): 798 si
« Reply #2 on: October 28, 2010, 05:42:34 AM »
Thanks for that advice. (i think)
It seems I am better at fishing than operating this machine, I gave it three hours today, and am more confused. When i converted the file from GE it still wasnt a gpx file, it said a the file name followed by.gpx however it stated it was a HWR file and HB PC wouldnt look at it. Im sure its simple once your setup ??? ??? ???
« Reply #3 on: October 28, 2010, 12:24:38 PM »
Barmic,
I tried this just this morning with some waypoints only.  Set them in GE and than saved as a *.kml file.  Used GPSBabel to convert them to the *.gpx file format and could open that file in HummPC.  Not sure where you went wrong there.
Offline Barmic
  • Regards Barmic
  • Unit(s): 798 si
« Reply #4 on: October 29, 2010, 02:26:34 AM »
Thanks guys It seemed i didnt select the right output file format and needed the gpx xml format, I get a strange box apearing prior to loading the file to HB PC but it loads and works a treat.  Thank you :) :)
Last post May 27, 2011, 12:08:21 PM
Last post August 27, 2012, 04:11:04 PM
Last post March 21, 2013, 12:40:37 AM
Last post April 25, 2014, 03:40:47 AM
by slabbacks
Last post September 16, 2014, 09:56:27 AM
by Sawyer
Last post July 05, 2016, 10:24:17 PM
by coldsteel
Last post January 09, 2017, 02:01:29 PM
Last post June 10, 2021, 06:34:34 PM
by ezfishn
