Author Topic: 998 sd card slot  (Read 8706 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
998 sd card slot
« on: April 26, 2021, 08:29:13 PM »
The right side card slot won't seat the card, it will not stay down. Is there any fix to this? Thanks in advance for any help.
Re: 998 sd card slot
« Reply #1 on: April 26, 2021, 09:26:10 PM »
There was an early issue with the 998 that closing the SD Card slot door itself would occasionally pop the SD Card out of its slot  ...
Is this your issue or will the SD Card not stay seated even with the SD Card slot door open  ... ??
Offline 6speedy3
« Reply #2 on: April 26, 2021, 10:00:39 PM »
It doesn't seat with the door open.
« Reply #3 on: April 27, 2021, 07:02:28 PM »
Have you tried a different SD Card to verify it is something inside the slot causing the issue  ...??
998 is no longer on the HB service list  ...
Offline 6speedy3
« Reply #4 on: April 27, 2021, 07:09:12 PM »
Yes, I have tried several cards. I know 998 is not supported by Humminbird now. So called Legacy unit.
Last post March 03, 2010, 08:14:50 AM
Last post June 05, 2011, 06:04:09 PM
Last post May 17, 2012, 09:35:58 AM
by koz54
Last post July 12, 2012, 11:42:48 AM
Last post September 09, 2013, 01:33:07 AM
by LocDown
Last post August 26, 2014, 06:53:11 PM
Last post February 09, 2015, 03:46:05 PM
Last post December 28, 2019, 09:59:24 PM
by h8go4s
