Author Topic: Details of SD card slot capability  (Read 15244 times)
Offline SpineyNole
  • Unit(s): 1197c si
  • Software: 4.950
  • Accessories: custom towfish
« on: February 08, 2015, 02:10:40 PM »
Greg or someone else in the know, would like to know some detailed information about the SD card slots in the Humminbird SI units (in my case the 1197):
What SD card standards do the SD card slots in the 1197 support? SD (standard) or SDHC (high-capacity) or SDXC (ultra-high-capacity)? High Speed (HS) or Ultra High Speed (UHS)? If HS, Class 6 or Class 10? If UHS, UHS-class 1 or UHS-class 3?
I know that in the past, Greg recommended SanDisk Extreme-III SDHC cards if you desire to record sonar data, but those cards are no longer in production. They currently sell Standard, Ultra, Ultra Plus, Extreme, Extreme Plus, and Extreme Pro. Of these being produced now, which do you recommend for sonar recording?
What write speed is required to support sonar recording. If we knew that, the choice for SD card would be simple.
Also, do all Humminbird SI units use the same capability SD slots?
Would be nice if we had a table that would supply this information for all the SI units. Would make it much easier to determine which SD card to buy for the user's desired use.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Details of SD card slot capability
« Reply #1 on: February 08, 2015, 09:24:08 PM »
When I first started recording four years ago, I had to purchase the SanDisk Extreme to get a rate of 30MB/s.
Awhile ago SanDisk changed the recording rates on the Ultra to 30MB/s and the Extreme to 45MB/s.
I have had good results with the 30MB/s cards. Be careful as there are some old cards (lower rate) still out there.( Ultra's at 15MB/s)
              Mike
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #2 on: February 09, 2015, 08:06:57 AM »
SDXC  is not supported, 32GB is max size.
Offline N9Phil
« Reply #3 on: February 09, 2015, 08:15:06 AM »
The faster cards have the ability to copy your info faster.  I believe that most use an ultra or faster card.  I just use the fastest card that I can find available and have never had a problem.  I have even used the micro cards in an adapter and have not had a problem.  I just checked and all of my current cards are ultras.
Phil
Offline sfw1960
« Reply #4 on: February 09, 2015, 10:00:55 AM »
I have used class 6 cards with no issue at all.
« Reply #5 on: February 09, 2015, 03:46:05 PM »
Our units support the SD and SDHC type memory cards.
Last I heard was that we tested an SDHC memory card with a speed class rating of 6 and it worked fine.  This was at least a year ago and may have changed but I have not heard otherwise.
We have not always (nor I doubt in the future) ever always used the same SD card reader in our products.  Times change and parts availability change as well.
Last post March 03, 2010, 08:14:50 AM
Last post June 05, 2011, 06:04:09 PM
Last post May 17, 2012, 09:35:58 AM
by koz54
Last post July 12, 2012, 11:42:48 AM
Last post September 09, 2013, 01:33:07 AM
by LocDown
Last post April 30, 2014, 03:08:02 PM
by tdclaymc16
Last post August 26, 2014, 06:53:11 PM
Last post May 27, 2016, 05:01:34 PM
by curt66973
