Author Topic: 2d transducer lost  (Read 10829 times)
Offline Skeeter07
  • Unit(s): 1198 c si, 899ci hd si, 798ci si
  • Software: lastest
  • Accessories: none
2d transducer lost
« on: June 01, 2018, 06:48:17 AM »
Got solix units networked and was picking sonar sources.  I picked for depth 1 the transducer that's connected to unit but said selected 2d transducer (Lost).  After a few min. lost went away.  See picture.  Why would lost show when it connected to unit I was setting it up?  Also why are there two gps and depth to pick?  Is 2 in case number 1 fails? Thanks.
Re: 2d transducer lost
« Reply #1 on: June 01, 2018, 11:17:33 PM »
Networking is designed to "look for" the next best source if the selected source is lost for any reason  ...
A source "Lost" indicates a bad connection or a failing device  ...
You might disconnect and reconnect the xducer connector to see if there may be a bad connection  ...
Offline TroyBoy30
  • Unit(s): 1198
« Reply #2 on: August 14, 2018, 11:26:07 AM »
it will also show lost on a transducer that has pinging turned off.  there are 2 options for a main and a backup.  some options have as many as 4 options
« Last Edit: August 14, 2018, 11:27:21 AM by TroyBoy30 »
Last post April 02, 2010, 03:52:00 PM
by eric3338
Last post May 10, 2010, 11:31:41 AM
by doninlouisiana
Last post August 21, 2011, 09:30:43 PM
Last post July 18, 2013, 01:05:07 PM
by iceimanhunting
Last post February 13, 2014, 02:38:37 PM
Last post November 18, 2014, 04:01:51 PM
Last post June 11, 2017, 08:14:26 PM
by Mark Saikaley
Last post May 03, 2025, 08:22:46 AM
by JWN
