Author Topic: 797 SI lost hi res after update  (Read 20871 times)
Offline eric3338
  • Unit(s): 998c si nvb ,797c2 SI nvb
  • Software: 4.880, 4.770
  • Accessories: interlink weather sence
« on: March 31, 2010, 07:45:24 PM »
  I did the update to the DI. Yes I reset my defaults to original settings.  I took the boat out and was very let down.  The DI worked fine, really liked it.
  Problem>  It took all the resilution away for the SI.  It will hardly show the shore line and what  pixels that are marking something are now huge Looks like large rectangles.  I would rather have my SI back than the DI.   Help me Is there a software that will give me color change without the DI.  Or do you have any other  suggestions?  Please help .
Eric :-[
Re: 797 SI lost hi res after update
« Reply #1 on: March 31, 2010, 08:52:17 PM »
Eric,
Can you post us a snapshot of the SI screen if you have one?  If you have any old recordings, play them back and see if it does the same thing and take a snapshot for us to see.
Also, check your settings and let us know what they are.
Worst case scenario is to re-install previous update, then install the new one again.
A picture is worth a thousand words!
Offline Bass797
  • Unit(s): 797c2 SI
  • Accessories: Trolling Motor XTM 9 SI 180 T
« Reply #2 on: April 01, 2010, 08:44:12 PM »
Hello,
I’ve had my 797c2 si for over 2 years now, I to just updated the software (V4.770) on my 797 last week when I first turned the unit on the si was very dark couldn’t see anything but after adjusting the color and sensitivity both Si and Di are very clear and sharp, the only thing now is I lose bottom at about 6 feet or less with the sonar and it goes nuts flashing 300 to 400 feet and the sonar image is all jagged, when I get back into deeper water I half to power off and on to clear it.
I think the software may a few bugs yet.
Offline eric3338
« Reply #3 on: April 01, 2010, 09:47:27 PM »
bass  I had that before the software update. But didn't have to shut it off for it clear.  Am going out tommarrow  and mess with it some more.  Hope your right and it clears up.
« Reply #4 on: April 02, 2010, 01:00:29 PM »
For the dark Si sonar try downloading and install an older version software update to your unit than download an new copy of the current Si software and re-install it in your unit.
For the 2D sonar jumping around in shallow water try setting the Water Type menu to the Salt (deep) setting and increase the Surface Clutter menu setting.
Offline eric3338
« Reply #5 on: April 02, 2010, 03:52:00 PM »
ok ok  I forgot the manual settings was so weird  I alsways had it on auto and no I can see.  Brain fart.  Really need to play with it more.  Thanks for all you help.  I guess I was so excited about the download I just jumped to conclusions.  Only really get on the water once or twice a weekend. :)
Last post April 13, 2009, 06:27:55 PM
Last post August 31, 2009, 07:17:36 AM
by mrj9600
Last post April 26, 2010, 02:29:54 AM
Last post February 10, 2011, 10:44:25 AM
by The bird
Last post March 06, 2011, 04:06:53 PM
by bryanmc
Last post February 01, 2012, 12:15:48 PM
Last post July 27, 2014, 02:28:52 AM
by Hennessyt
Last post January 05, 2021, 10:12:09 PM
by RiverDewey
