Author Topic: Helix 9 CHIRP MEGA DI GPS G3N Transducer Compatibility  (Read 14526 times)
Offline RivRunR
  • Lowe Roughneck 1752 VPT
  • Unit(s): 898c SI, i-Pilot Link
  • Software: 6.61
  • Accessories: GPS, WeatherSense
« on: March 18, 2019, 03:12:57 PM »
I have a Helix 7 CHIRP DI G2 with a XTM 9 DI 25 T transducer.  The transducer cable has been routed down the shaft of my MinnKota Terrova with 3M 4200 adhesive.
I'm thinking of replacing that Helix G2 unit with a HELIX 9 CHIRP MEGA DI GPS G3N and wanted to make sure that the XTM 9 DI 25 T is compatible.
Hbird's transducer chart seemed to say it was, but I noticed that their description of the Helix G3N mentioned something about a "low-Q" transducer, so I wanted to be sure before I pulled the trigger since the XTM 9 DI 25 T cable is kind of "stuck" to the Terrova.
Thx,
Will
« Last Edit: March 18, 2019, 05:41:42 PM by RivRunR »
FHB
Re: Helix 9 CHIRP MEGA DI GPS G3N Transducer Compatibility
« Reply #1 on: March 18, 2019, 11:29:07 PM »
G3N is "compatible" with the XTM 9 DI 25 T by changing the Connected Transducer selection to "DI + 200/455kHz"  ...
You just won't have the benefit of the Low Q xducer that comes stock with the G3N  ... (Somewhat cleaner 2d images)  ...
Offline RivRunR
  • Software: 6.61
« Reply #2 on: March 25, 2019, 02:01:28 PM »
Yeah, HBird emailed me to say "if you are wanting MEGA DI, you will need to use the transducer that comes in the box with the G3 unit because the HELIX G2N DI and HELIX G3N MEGA DI units have different transducers"
So I guess I'll exchange the G3N transducer in the box for a XTM 9 HW MDI T, and then do the Terrova cable routing all over again.
Thanks!
Will
FHB
Last post May 05, 2019, 10:56:54 PM
Last post October 27, 2019, 04:49:01 AM
by reso
Last post November 21, 2019, 05:35:54 PM
by KJINTF
Last post March 14, 2020, 01:34:42 AM
Last post June 06, 2020, 09:52:35 PM
Last post August 11, 2020, 11:12:55 PM
Last post April 14, 2022, 10:09:49 PM
Last post April 15, 2022, 09:46:26 PM
