Author Topic: Routes color - unreadable info - connection lost!  (Read 10771 times)
Offline The bird
  • Computers - Boating - Family, Friends.
  • Unit(s): 798C Si
  • Software: 4.960
« on: February 07, 2011, 11:28:32 PM »
Hello;  :)
Translated with Google because I do not understand English;
1-I am doing some routes on the computer color magenta, but when they are transferred to the GPS it is a green "army green", not very visible.
      Is it possible to choose or change the color of a road on the GPS.
Here is an example;
[ Specified attachment is not available ]
2 - If possible, apply the update to magnify information (depth, no buoy) on the map. It is almost unreadable, it would take a magnifying glass!!
Here is an example of card easy to read;
3 - Also, it would be convenient to have the option Simulation, Normal and PC in the menu page, instead of always having to close / open the device.
4 - When I move the GPS based, the GPS goes out.
It seems that the connection of the son is not sufficiently tightened.
Sorry i have problem whith post!!!!!
Thank you, goodbye.  :)
« Last Edit: February 07, 2011, 11:46:23 PM by The bird »
The bird. Thank You!!!!
Better to be patient on the road, a patient at the hospital!!
Offline babarosa
  • Unit(s): 798ci
  • Software: 4.780
Re: Routes color - unreadable info - connection lost!
« Reply #1 on: February 09, 2011, 12:12:32 PM »
I'm assuming you are working with the Installed map on your unit. So you may have to toggle between hotmaps or gold, auto select is not always the best. Pay attention to your zoom levels and make sure your spot soundings are turned on. Additional nav cards can be added for more detail. The nav line can be modified via the menu{type,color,and depth}, as far as visibility ,zoom seems to make all the difference. Accuracy seems to be better at higher zooms. As far as the power going out you might try bending the pins on the power cord just a little, hope this is what your asking about, good luck.
Offline The bird
  • Unit(s): 798C Si
  • Software: 4.960
« Reply #2 on: February 09, 2011, 02:37:44 PM »
Hello:
In Select card, I have 3 Choice;
Auto; contour XD; card right? Either it does not change anything.
I HotMaps on SD card, but I do not see the choices?
Puts the zoom levels on the water at 250m, but more or less does not change the numbers of buoys and depth, I use a lot.
The time survey is Visible;
In menu / Views / wholesale figures; it to Visible;
In menu / Views / View Map; Visible;
In Menu / Nav; by Color depth is 200pi.
In Menu / Road / Edit, there is no choice of color. The only name or WP Rte.
But that changes nothing!
For management, I dare not touch the pine, because it is still guaranteed!! By cons I can bend the metal bar that supports son!!
Thank you very much. :)
Offline babarosa
  • Unit(s): 798ci
  • Software: 4.780
« Reply #3 on: February 10, 2011, 08:57:02 AM »
main menu under current track, scroll right, scroll down choose color and style.
Offline The bird
  • Unit(s): 798C Si
  • Software: 4.960
« Reply #4 on: February 10, 2011, 10:44:25 AM »
Hello: :)
Quote
This is not for the Saved Tracks is for Routes.
I wish I had the same thing for Routes, but I can not find.
Also, how do they do not change color when transferring?
Last post February 15, 2011, 11:04:53 AM
by Amphib206
Last post April 28, 2011, 04:15:32 PM
by BalticProject
Last post April 04, 2012, 02:06:11 PM
Last post April 20, 2012, 10:51:39 AM
by LBloch
Last post May 14, 2012, 09:16:59 PM
by Rocketman783
Last post May 20, 2013, 01:48:37 PM
Last post September 18, 2018, 11:22:35 AM
Last post August 05, 2024, 05:42:02 AM
by tournevase
