Author Topic: 898 si side and down images not working  (Read 7649 times)
Offline prmx
  • Unit(s): 997c si 798 si helix 5 si
  • Software: newer
« on: September 13, 2017, 06:00:46 PM »
I have 898 Unit, my side and down image does not work, normal sonar ok the problem occurred after navigating in my bass boat the connector of the transducer was disconnected and reconnected with the unit turned on, sending photos, and I tried another transducer , another cables, software update and I still have theila_rendered same problem, send photos
Re: 898 si side and down images not working
« Reply #1 on: September 13, 2017, 09:58:03 PM »
Have you tried Restore Defaults under the Setup tab  ...??
Offline prmx
  • Software: newer
« Reply #2 on: September 14, 2017, 10:50:11 AM »
yes Rickie,
« Reply #3 on: September 14, 2017, 08:59:42 PM »
As you've already tried another xducer with the same results  ... there is a slim chance both xducers could be bad  ...
About the only other troubleshooting might be to try a different unit on your boat  ...just to verify that the xducer is not faulty  ...
Offline prmx
  • Software: newer
« Reply #4 on: September 15, 2017, 11:11:05 AM »
i have on the troll motor a 997 si unit working, with no problems, change the units and the 898 have the same problems in the two sides, and the 997 works in the 2 sites
« Reply #5 on: September 15, 2017, 10:54:09 PM »
You've narrowed it down to the unit  ...
Here's the flat rate charge schedule to decide if you want to send it to HB  ...
https://www.humminbird.com/Category/Support/FAQ/RepairFees/
Last post October 10, 2009, 12:04:03 PM
Last post April 05, 2010, 06:42:06 PM
Last post July 01, 2011, 02:49:53 PM
Last post August 21, 2012, 08:26:29 PM
by Ricky
Last post February 06, 2016, 11:53:30 PM
Last post June 18, 2018, 11:09:25 PM
Last post December 17, 2020, 09:15:06 PM
by Planokeith
Last post May 03, 2021, 10:56:52 PM
