Author Topic: Helix 10 G2n Mega SI won't display saved waypoints  (Read 14670 times)
Offline h8go4s
  • Unit(s): 898C SI
« on: September 09, 2017, 12:55:46 PM »
Installed this spring, worked fine. Tried to update to V1.460, restorimg defaults first per instuctions. Unit locked up, showing "shutting down" screen. I sent it in to HB and they repaired and updated it under warranty. Now it does not save waypoints properly. When I push the mark button, it shows a new waypoint, displayed as a blue dot. Each waypoint has a new consecutive number (I'm up to WP016). But once the unit is turned off and back on, no waypoints are visible on the screen. In the waypoint management dialog box, no waypoints are shown, yet each time I mark a waypoint, it is displayed on the chart screen and the  number is incremented. I've gone through all the waypoint management options and can't figure out a solution. I suspect I'll have to send it back to HB, but don't want to do that again until winter.
Re: Helix 10 G2n Mega SI won't display saved waypoints
« Reply #1 on: September 10, 2017, 08:29:54 AM »
Have you tried Restore Defaults since receiving the unit back from HB  ...??
Offline h8go4s
  • Unit(s): 898C SI
« Reply #2 on: September 10, 2017, 09:47:59 AM »
No, because the last time I did that, to attempt to install V1.460, it locked up and I had to send it to the factory to get it fixed. I'm not doing that again until I put the boat away for the winter.
« Reply #3 on: September 10, 2017, 09:46:05 PM »
Are you creating the way points in Normal of Simulator mode  ...??
Offline h8go4s
  • Unit(s): 898C SI
« Reply #4 on: September 10, 2017, 10:04:17 PM »
Normal mode. When I'm actually on the water fishing and navigating with a Lakemaster card.
« Reply #5 on: September 11, 2017, 10:06:46 PM »
Restore Defaults is going to be the best advice I can give  ...
There have been reports of weird unit functionality if there is a corrupt waypoint in the unit memory  ...
You might export your waypoints to an SD card and look at them in Humminbird PC  ...
Look for odd dates, duplicate waypoints, odd waypoints formatting, waypoints with any characters except numbers and letters  ...
Offline NJsquatch
  • Unit(s): Helix 7 & 363
« Reply #6 on: October 28, 2020, 01:51:43 PM »
h8go4s
did you ever get this issue resolved? i am experiencing the same issue on my Helix 5 Chirp GPS G2.
I have restored the default settings and formatted the nav directory after backing up my waypoints and the unit is still misbehaving.
« Reply #7 on: October 28, 2020, 07:22:13 PM »
There were some earlier software versions in which a waypoint was not saved if “Screenshots” under the Accessories tab was toggled On while there was no SD Card inserted in the unit  ...  ...
Offline NJsquatch
« Reply #8 on: November 18, 2020, 05:01:55 PM »
in case anyone else has this issue i had to send my unit in for repair. the repair order says "repair circuit board"
I am speculating that the internal memory chip was loose since i was also not able to update the firmware.
Last post April 01, 2016, 12:14:30 AM
Last post April 18, 2017, 07:40:31 AM
by RivRunR
Last post June 04, 2017, 04:47:41 PM
Last post September 08, 2019, 11:45:19 AM
by frankie_fin
Last post August 15, 2017, 12:57:21 AM
by Oz306
Last post October 04, 2017, 06:33:17 PM
by Stumpy
Last post December 12, 2017, 09:23:55 PM
Last post October 22, 2018, 01:46:43 AM
by Vicus Horn
