Author Topic: Helix 12 Mega CHIRP - Split Sonar View - No Left (83 kHz) Display?  (Read 24429 times)
Offline RivRunR
  • Lowe Roughneck 1752 VPT
  • Unit(s): 898c SI, i-Pilot Link
  • Software: 6.61
  • Accessories: GPS, WeatherSense
This is probably a stupid, menu-related question, but the Split Sonar View on my Helix 12 Mega doesn't display any returns on the left (83kHz) side of the screen.  It's completely blank except for "Medium" as the frequency display.  All other views seem to work fine.
The 2D transducer is a XP-9-20 Puck with a MSIDB-Y Y-Cable.
Thx,
RR
FHB
Re: Helix 12 Mega CHIRP - Split Sonar View - No Left (83 kHz) Display?
« Reply #1 on: April 11, 2017, 03:55:26 PM »
Check to see if there is an update in your account .... if not give Humminbird a call.
Offline RivRunR
  • Software: 6.61
« Reply #2 on: April 11, 2017, 04:16:07 PM »
There is an update, but it doesn't mention anything about Split Sonar as one of the fixes.
I did finally find this in the manual (p. 42): 2D CHIRP Display Frequency- "If High Frequency is selected, the medium frequency beam is not available."
So, since I had selected High Frequency, and the left side in Split Sonar says Medium frequency, then perhaps that's why it's not showing up?
When I flipped the frequency from High to Medium/High during playback nothing changed but, if "the medium frequency was not available" during recording, I'm guessing that I'll have to put it back in the water to test that theory.
FHB
« Reply #3 on: April 11, 2017, 04:29:27 PM »
I'd go ahead and do the update ..... can't help with the setting since I don't have a chirp unit.
« Reply #4 on: April 15, 2017, 08:21:38 PM »
You mention "during playback"  ...
Are you playing a recording back on the unit  ...??
Are you playing the Simulator recording  ...??
Offline RivRunR
  • Software: 6.61
« Reply #5 on: April 17, 2017, 07:53:56 AM »
I'm playing a recording on the unit (not the Simulator).  At the time of the recording, the 2D CHIRP frequency was set to High.
Will
FHB
« Reply #6 on: April 17, 2017, 11:18:07 PM »
Will
If you recorded with the frequency set on high - then the 83kHz (or Medium in CHIRP) would not have recorded to the SON files  ...
I record on my 1197 with the 83kHz shut off simply to make the recording files smaller  ...
If you want the 83kHz (or Medium in CHIRP) to be available in a recording playback - it will have to be enabled before starting the recording process...
« Last Edit: April 17, 2017, 11:21:20 PM by rnvinc »
Offline RivRunR
  • Software: 6.61
« Reply #7 on: April 18, 2017, 07:40:31 AM »
Thanks Rickie, I appreciate the explanation!
FHB
Last post December 14, 2009, 10:31:30 AM
Last post April 08, 2017, 08:17:56 PM
Last post October 22, 2018, 01:46:43 AM
by Vicus Horn
Last post March 05, 2019, 08:52:33 AM
Last post April 16, 2019, 03:38:56 PM
by cat_in_the_hat
Last post June 06, 2020, 09:52:35 PM
Last post August 11, 2020, 11:12:55 PM
