Author Topic: 998 screen goes dark on boot up  (Read 12742 times)
Offline knorstu
  • I work therefore I fish!
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« on: July 13, 2017, 02:09:25 PM »
Hi guys,
    Looked through other notes but thought I would ask anyway.
   I have a 998 that occasionally goes dark on boot up when the unit would normally start displaying the sonar screen. I have plenty of power as I was on a fly-in trip using a running 20HP motor connected to it's starting battery. On the dark screen I could hit the power button to get the shutdown screen. I could see it but was very very dark. Light setting was at the max.
   I would reboot. Sometimes it would work. Other times I would have to do it several times to get it working.
   Another person on our trip had the same model. He had the same issue with his once in a while.
   Any suggestions would be helpful. Thanks!
Re: 998 screen goes dark on boot up
« Reply #1 on: July 13, 2017, 09:14:07 PM »
Is the unit functional enough to get to the Restore Defaults under the Setup tab  ...??
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #2 on: July 14, 2017, 05:27:55 PM »
Yes, the unit works fine. It's just dark on boot up once in awhile.
« Reply #3 on: July 14, 2017, 07:10:10 PM »
It sounds like the back light is failing  ...
Try Restore Defaults anyway when you can  ...
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #4 on: July 19, 2017, 08:51:48 PM »
Just found the unit quits pinging once the screen goes dark.
« Reply #5 on: July 19, 2017, 10:49:30 PM »
Similar symptoms can be caused by a weak battery or insufficient wire gauge to the unit  ...
Is the unit wired directly to the battery with 14 gauge or heavier wire  ...??
Offline knorstu
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« Reply #6 on: July 20, 2017, 04:27:40 PM »
When I was in Canada, I had the Humminbird power cable directly connected to the battery.
« Reply #7 on: July 20, 2017, 09:54:56 PM »
Here is the flat rate repair list and instructions  ...
https://www.humminbird.com/Category/Support/FAQ/RepairFees/
There is this option also  ...
http://www.clearcastmarine.com
Last post May 11, 2010, 12:09:20 PM
by TrickStick
Last post May 16, 2010, 09:59:16 AM
by alibobforever
Last post March 24, 2011, 11:44:54 PM
by jorawil
Last post March 19, 2012, 12:34:33 PM
Last post July 12, 2012, 06:09:29 PM
Last post July 23, 2012, 01:30:07 PM
Last post August 11, 2014, 05:15:27 AM
by phb
Last post December 15, 2014, 03:27:04 PM
