Author Topic: dark screen in deeper water  (Read 8980 times)
Offline ficht158
  • Unit(s): 998 c si
  • Software: 5.45
« on: March 17, 2012, 06:52:15 AM »
when i get in water over say 30 ft my screen get very dark.  what settings do i need to change to lighten this.  ive seen some really good pics in deep water and i cant get anything like it.
I think this is just a setup problem
thanks for the help
Re: dark screen in deeper water
« Reply #1 on: March 17, 2012, 10:05:37 AM »
158. pending another reply could you post a snapshot of the issue.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: March 18, 2012, 09:50:28 PM »
ficht158
      Try this if it happens again. Both of these settings are in X-press menu. ( one press of the menu button )
      Set the SI sensitivity to auto.
      Set the SI range to 3 or 4 times the depth. ie... 30' depth would be 90' to 120' on SI range.
      There could be other issues, but it's a place to start.
« Reply #3 on: March 19, 2012, 09:49:11 AM »
It seems to me you may have a power supply problem.
I'm not sure, but I think the deeper you go, the more power the
tranducer needs in order to ping deeper.
I'd fully charge your battery and load test it.
« Reply #4 on: March 19, 2012, 12:34:33 PM »
It would be nice to see a Screen Snapshot of this and to know what menu settings and software version you are using in your 998c Si unit.
If possible; test your 998 unit on someone else’s boat that is also running a Humminbird Si unit (does not have to be the same model number) and see if you get the same results or not.
Last post May 11, 2010, 12:09:20 PM
by TrickStick
Last post May 16, 2010, 09:59:16 AM
by alibobforever
Last post March 24, 2011, 11:44:54 PM
by jorawil
Last post July 12, 2012, 06:09:29 PM
Last post July 07, 2014, 03:40:23 PM
by didier74
Last post December 15, 2014, 03:27:04 PM
Last post July 20, 2017, 09:54:56 PM
Last post May 28, 2020, 12:14:39 PM
