Author Topic: dark screen  (Read 15896 times)
Offline jorawil
  • Unit(s): 898c SI
dark screen
« on: March 13, 2011, 02:39:31 PM »
Can't read screen in si Di mode. Screen is fine in all other modes.
Re: dark screen
« Reply #1 on: March 13, 2011, 03:49:57 PM »
Reply with your unit type and software level.  Any other attachments you might have also. Like transducer type...
Offline bamafish
  • Unit(s): 898csi 1198csi
  • Software: 6.18 6.49
  • Accessories: gps
Re: dark screen
« Reply #2 on: March 13, 2011, 05:19:01 PM »
 My screen went dark about a month ago while fishing. I unplugged everything from the unit, waited a minute and plugged everything back in and turned the unit on and it has worked fine since. If you haven't tried this it might be worth a try.
Offline jorawil
  • Unit(s): 898c SI
Re: dark screen
« Reply #3 on: March 15, 2011, 11:19:35 PM »
My software version is 5.210.  Transducer is what came with unit.
Offline jorawil
  • Unit(s): 898c SI
Re: dark screen
« Reply #4 on: March 15, 2011, 11:21:52 PM »
Unit is 898c si.
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: dark screen
« Reply #5 on: March 15, 2011, 11:45:56 PM »
Yes.... sunglasses glasses will affect the brightness of the screen.  One thing that will help is purchasing a Raptor Cap Visor to use.  I have one and thye work great.
Offline jorawil
  • Unit(s): 898c SI
Re: dark screen
« Reply #6 on: March 18, 2011, 11:21:50 PM »
Thanks I just ordered a raptor cap.
Jorawil
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
Re: dark screen
« Reply #7 on: March 24, 2011, 10:11:28 PM »
Check your sensitivity setting for the SI screen.  If you set it to auto it will vary the screen brightness along with the sensitivity setting going up or down depending on the depth of the water and the range you have it setup for.
Try manually setting the sensitivity up to about 20 to see how bright the screen gets at the max sensitivity setting. Then set it back down to around 3 or 2 and note the difference.
If you know the lake you are fishing you may be able to just set the settings manually and set them up higher.
I have a raptor shield on my unit too and it does help some.  But these screen can still be hard to see in bright sunlight.  I plan on putting an umbrella over my seat where the unit is located to shade it even more so that I can see the screen better.
And Polarized sunglasses blocks out a lot of the light rays.  Any polarized light that's in the vertical and that's bouncing off a reflective surface will be blocked out by the polarized sunglasses.  But the light that's polarized at 90 Deg to that blocked light will get through the sunglasses.
Light is polarized by the reflecting surface and at right angles to the light rays line of travel.
Jorawil
« Last Edit: March 24, 2011, 10:14:19 PM by Moose1am »
Regards,
Moose1am
Offline jorawil
  • Unit(s): 898c SI
Re: dark screen
« Reply #8 on: March 24, 2011, 11:44:54 PM »
Update on original post. I ran wires from the battery directly to the 898c . I also raised the si sensivity up and the screen is a good bit brighhter.  Down scan and side scan are eaiser to see now. I have not installed the raptor cap yet. I hope that the problem I was having is solved. Thanks for all the suggestions.
Last post May 11, 2010, 12:09:20 PM
by TrickStick
Last post May 16, 2010, 09:59:16 AM
by alibobforever
Last post March 19, 2012, 12:34:33 PM
Last post July 12, 2012, 06:09:29 PM
Last post June 18, 2014, 10:18:48 AM
by hop307
Last post June 30, 2014, 01:30:06 PM
Last post December 15, 2014, 03:27:04 PM
Last post July 20, 2017, 09:54:56 PM
