Author Topic: Helix 9 SI transducer location  (Read 8962 times)
Offline ga284
  • Unit(s): Helix 7
  • Software: 7.780
« on: May 02, 2017, 09:10:47 PM »
I just bought Helix 9 SI. I currently have a Helix 7 DI. The transducer is mounted on the starboard side of the transom. I get good sonar depth readings at speed with transducer mounted in this location. Do you think I would get good depth readings at speed if I mounted the SI transducer in the same location ?
Re: Helix 9 SI transducer location
« Reply #1 on: May 03, 2017, 08:47:39 AM »
This location "looks" as though the xducer has good contact with the water flow  ...
And you already have the benefit of a mounting board in case the installation needs tweaking  ...
Definitely worth a test in that location  ...
Last post February 19, 2010, 03:51:33 PM
Last post April 04, 2016, 10:15:28 PM
Last post May 14, 2017, 11:15:29 AM
by Dieago
Last post August 15, 2017, 12:57:21 AM
by Oz306
Last post February 15, 2018, 09:11:02 PM
Last post June 16, 2018, 01:53:20 PM
Last post June 27, 2018, 05:48:46 PM
Last post June 02, 2023, 09:14:12 AM
by kpkyllo
