Author Topic: humviewer not working  (Read 17002 times)
Offline dogcharmer
  • Unit(s): 1197si
  • Software: new one
« on: March 25, 2010, 09:28:29 PM »
really dissapointed, can't get this to play anything, tried for 2 days now, and all I can get is a partial view and there are no play buttons
FRUSTRATED!
Offline dybvad417
  • Wreckhunter in the Kattegat, Denmark
  • Unit(s): 987 Cx SI
  • Software: 4.750
Re: humviewer not working
« Reply #1 on: March 26, 2010, 05:54:27 AM »
FRUSTRATED!
You FRUSTRATED!  ::)
How do you think i feel when i read this.
Absolutely NO information about anything   :o
Your unit ?
Your PC ?
Your OS
How do you expect we can help you.  :-\
More info please.
Regards
Gert
Offline dogcharmer
  • Unit(s): 1197si
  • Software: new one
« Reply #2 on: March 26, 2010, 07:17:19 AM »
ok fine 1197 humminbird
humminbird pc
humviewer
dell computer,windows xp
program is there I guess, I can open it
when I tried to open a file I got a little bit of color on the top right of the screen and its not moving and I have no way to move it, my screen doesn't have any play buttons
I don't know what else to tell you
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #3 on: March 26, 2010, 08:08:13 AM »
Hello dogcharmer and welcome to the forum!
Your problem is the screen resolution setting of your PC/laptop monitor.
Change it or download the second version of Humviewer for lower screen resolutions.
Good luck!
Harry
YES,......
WE SCAN!
Offline George
  • Software: Always up todate
« Reply #4 on: March 26, 2010, 09:32:35 AM »
dogcharmer
First off I have a Dell with XP, so it should not be your computer.  Recently another person had the same problem the play button was missing, and he had reloaded HumViewer several times without success.  I recommended that he totally remove Humviewer from his computer then shut the computer down and the reload Humviewer, this worked.  Go to the control panel then to Add or Remove Programs and remove Humviewer, the turn you system off and reinstall.  Give this a try it may work,  Also, I would make sure when turning on your system you give it enough time to be fully loaded before reloading (make sure you go back to the site and download a fresh copy).
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
  • Accessories: Speed sensor
« Reply #5 on: March 26, 2010, 10:08:02 AM »
Hi
As Harry wrote this sounds like your screen resolution is too low. The HumViewer program requires at least 1024x768.
Higher = better.
Lower = Will not work
If you are running higher resolution then reinstall the program as George recommends.
/Martin
Offline dogcharmer
  • Unit(s): 1197si
  • Software: new one
« Reply #6 on: March 26, 2010, 06:40:29 PM »
thank you thank you thank you
works now
Offline Jolly Roger
  • HB Addicted
« Reply #7 on: March 27, 2010, 02:58:30 PM »
 ;D Was the screen resolution, right?
Regards / Harry
YES,......
WE SCAN!
Last post July 13, 2010, 04:12:35 PM
Last post April 14, 2011, 04:20:41 PM
Last post June 25, 2011, 10:11:07 AM
by Daz
Last post June 22, 2011, 10:13:06 AM
Last post July 18, 2011, 11:57:52 AM
Last post May 02, 2014, 12:46:29 PM
by Alcyone
Last post January 17, 2017, 11:35:15 AM
Last post July 03, 2017, 09:42:29 PM
