Author Topic: humviewer 67 stoped working  (Read 10420 times)
Offline goodwinexplorer
  • Software: 4.18
« on: July 13, 2010, 07:59:44 AM »
it says it could not create the java virtual machine, have re loaded humverver no joy also updated java, still not working?
any advice?
Re: humviewer 67 stoped working
« Reply #1 on: July 13, 2010, 08:12:47 AM »
You might try searching the internet for JAVA related information.  JAVA runs with a lot of programs and it could be a mismatch with another program. Possbly a printer or scanner.
Instead of reinstalling java try deleting or unstalling it and then downloading a fresh install. same with Humviewer after Java is installed.
  • Software: 4.18
« Reply #2 on: July 13, 2010, 02:26:37 PM »
tried that still did not work, seema s comon proble with java help?
  • Software: 4.18
« Reply #3 on: July 13, 2010, 02:36:09 PM »
say i must reduce xmx switch in java, can not find it?
« Reply #4 on: July 13, 2010, 02:56:14 PM »
what computer are you using?  software, age of computer, amount of real memory? are you running other applications at the same time, is the internet running when you run humviewer?
Java can be a bit of a nasty problem.
  • Software: 4.18
« Reply #5 on: July 13, 2010, 03:39:28 PM »
desk top computer have had humviewer for a year have up dated, no problem, tried disconnecting the internet, redused virtual memory to 904 from 2040 rebooted same problem?
« Reply #6 on: July 13, 2010, 04:12:35 PM »
all that seemed to change is the Java.  It can be a problem. Maybe one of our computer junkies can get in on this also.
I am confused as you now.
Last post March 27, 2010, 02:58:30 PM
Last post April 14, 2011, 04:20:41 PM
Last post June 25, 2011, 10:11:07 AM
by Daz
Last post June 22, 2011, 10:13:06 AM
Last post July 18, 2011, 11:57:52 AM
Last post May 02, 2014, 12:46:29 PM
by Alcyone
Last post January 17, 2017, 11:35:15 AM
Last post July 03, 2017, 09:42:29 PM
