Author Topic: 798 first time out. SI/DI not working when it is deeper than 10 meters (30 ft)  (Read 17870 times)
Offline CHOOhonets
  • Unit(s): 998 HD SI
  • Software: 6.49
  • Accessories: AS SI LR Y cable
I've been out with my new 798 first time this weekend. SI is a perfect tool even with default settings - i'm impressed!
But the problem is that mine is not working when it is deeper than about 10 meters (30 ft).
I've attached a snapshot where a picture eliminates at certain depth...
Hope there is a solution ::)
PS With conventional 2D view everything works fine at any depth!
« Last Edit: June 15, 2011, 07:50:24 AM by CHOOhonets »
CHOOhonets,
Try testing your 798 unit on someone else’s boat that has a Humminbird SI unit or their unit on your boat.  You may have a transducer problem and this will be a way that we can confirm this.
Offline terry0540
  • Unit(s): 798ci SI NVB
  • Software: 4.780
  • Accessories: none
Try setting your SI range to 2 to 3 times the depth.
My unit looks like your pictures when my range is close to the depth
Offline CHOOhonets
  • Software: 6.49
Humminbird_Greg
Hardly anyone has an SI unit in my area so i won't be able to test it that way :'(
terry0540
I've tried setting SI range to 2 to 3 times the depth - it did not help unfortunately :(
It would be really sad if this is a transducer hardware problem because i've spent so much nerves exchanging my stock 798 transducer to HDSI...The best is often the enemy of the good ::)
Humminbird_Greg
terry0540
Usually if there is a problem like this… it’s the transducer.  Not always but I would bet money on it being a bad transducer.  You might want to contact the Humminbird Customer Resource folks and send in both the unit and transducer for testing.
Offline CHOOhonets
  • Software: 6.49
Thank you, Greg! I'll go this way!
Offline CHOOhonets
  • Software: 6.49
Theoretically, may the problem be in the software?
Yes in theory it could be in the software of the unit.  It could also be in the transducer or the hardware of the unit too.  Without being able to point to or eliminate the transducer though we are just guessing as to the root cause.
Offline Kimi
  • Unit(s): 798CXI 898 CXI
Looks to me that the bottom in the deeper area is plain soft mud. If it is so, it will appear at your screen as "black". Try somewhere else where you find harder bottom.
Kimi..  ::)
homepage: ( in Finish only) www.wreckdiving.yolasite.com
Offline CHOOhonets
  • Software: 6.49
I have found the solution but not shure if the situation is decent: to get the picture at 10 meters (30 ft) and more i have to set sensitivity almost to the maximum! Here are some snapshots from the same place that demonstrate this:
PS The depth is even less than 10 meters here (usually it works good at sensitivity about 10 at such depths but for some reason it was impossible to use that sensitivity level at that place), but it is the same way it works at 10 meters and more.
« Last Edit: June 20, 2011, 01:57:41 AM by CHOOhonets »
Offline CHOOhonets
  • Software: 6.49
Offline CHOOhonets
  • Software: 6.49
Humminbird_Greg
Would you please give your opinion whether the situation described is normal?! If it is not would you still blame the transducer in the first place?
Offline Del
  • Unit(s): 1197 SI
CHOOhonets, i'm far away from Gregs competence, but our (all) units showing a much brighter screen on sensivity 10. Sensivity 10-12 usually gives you the best picture, everything above makes it too bright. 15-20 is absolutly horrible to watch. I've been using my unit in more than 10m also, without changin the sensivity at all.
« Last Edit: June 22, 2011, 02:42:05 AM by Del »
Offline CHOOhonets
  • Software: 6.49
Thank you for your reply, Del! What do you think the problem is? Transducer?
Offline Del
  • Unit(s): 1197 SI
I'm no technican so i cant give you a qualified advise, actually most problems coming up in this forums are solved with a new transducer. For myself i could also immagine a bad unit, for example due to too less power output, creating weak signals. But actually you better listen to Greg at this point.
Good luck mate!
Offline CHOOhonets
  • Software: 6.49
Thanks a lot! ;)
Good luck mate!
I’m just going to agree with what Del said and guess that it is the transducer as this is not what I would call “normal” readings for that sensitivity level in that depth of water.
Last post December 31, 2010, 03:58:22 AM
Last post June 25, 2011, 10:11:07 AM
by Daz
Last post March 19, 2012, 12:34:33 PM
Last post July 12, 2012, 11:04:12 PM
by hang_14
Last post November 12, 2013, 11:03:44 AM
by Rüdiger
Last post July 07, 2014, 03:40:23 PM
by didier74
Last post May 28, 2020, 12:14:39 PM
Last post October 25, 2020, 03:17:00 AM
by zeebeest
