Author Topic: RFI problem with my HELIX 5 SI G2 Sonar  (Read 9162 times)
Offline BataBarnabas
  • Unit(s): Helix 5 SI G2
« on: January 07, 2017, 01:01:05 PM »
Hi,
I have Humminbird Helix 5 SI GPS sonar. In our country, man can only electric boat on the Lake Balaton be used (Hungary).
I bought one new 10 HP powerful electric outboardmotor for my boat.:-) ( Brushless, 3 faze electric motor ,48V, 5000W)
My Problem is that when the engine is started, the sonar sideimage and downimage pictures falls apart (RFI)! (There are many disturbing wave is on the screen. I tried to move the sonar head to forward, but did not improve the pictures. )
It can not be used for sideimagine or other viewing mode. :-(
What solution is there to this Problem?
Is there a usable Sonar Head, which would be wired to the electromagnetic disturbance is protected?
As anyone who wishes to be a wire? Aluminium tape?
I'm Follow the steps provided below to confirm and reduce this interference:
1. Motors may produce interference all speeds, I'm so tested at as many speeds as possible.
2. I have 2 Battery pack: 1. Main - Battery Pack 48 V, 100 Ah LithyumFePolymer ( 4 piece 12V 100Ah in series line) 2. Sonar and lighting Battery Pack: 12V , 45 Ah classic Battery. It is not connection in the two DC circuit. ! (separated)
3. NoiseFilter (ON) HELIX 5SI: no make better Image ween the motor is on.
4. I tried the sonar head in several Places on the Boat . But the Pictures is wrong.
5. I have not other sonar, and not networking, etc.
6. I do not hear the noise in my radio ... ??? !
7. The Interference is bigger in the 200 Hz and the 488Hz. ???? !
I have not Idea for Solution of this Problem... ???
Best regards,
Barnabas Bata
Re: RFI problem with my HELIX 5 SI G2 Sonar
« Reply #1 on: January 07, 2017, 06:28:25 PM »
The 1st troubleshooting step should be to determine if the RFI is encroaching into the xducer/xducer cable - the power circuit - or the head unit itself ...
Remove the xducer and xducer cable from the transom and test it in the water as far away from the motor as possible ...
If the RFI is gone = we know the RFI is encroaching into the xducer or its cabling ... and will then give a path forward for hopefully dealing with the RFI ...
Last post August 14, 2012, 08:12:57 AM
Last post September 27, 2012, 09:38:54 AM
Last post November 17, 2012, 09:31:37 AM
by Rickard
Last post April 16, 2013, 02:18:53 PM
Last post May 05, 2016, 12:12:26 PM
by sienaazis
Last post May 20, 2016, 11:16:05 AM
Last post October 28, 2016, 06:47:32 PM
Last post May 25, 2017, 08:16:21 PM
by wolfgrw
