Author Topic: Helix 10 Sonar GPS  (Read 12835 times)
Offline Surf N Turf
  • Unit(s): Helix 10 SI GPS, Helix Sonar GPS
  • Software: 1.210 For Both
  • Accessories: AS ETH 5PXG
Helix 10 Sonar GPS
« on: October 24, 2016, 12:12:42 PM »
I have a Helix 10 SI GPS @ the helm, and a Helix 10 Sonar GPS at the bow.  Both have the current software versions, 1.210.  I use Navionics + US & Canada cards in both, and both cards were updated Aug. 2016.  I have both units set to shade water depth deeper than 20'.  The SI GPS @ the helm works as intended.  The Sonar GPS unit at the bow does not.  The bow unit shades water shallower than 20'.  I have swapped the cards back and forth, no change.  All HB offered was to do a system default.  That did not help either.  Next recourse is to send the unit and mapping card in to HB.  Anyone have a tip or two on what setting to try?
Thanks in advance,
Gregory
Re: Helix 10 Sonar GPS
« Reply #1 on: October 24, 2016, 06:41:51 PM »
I have found that the Shaded Depth feature is no where near what the spot soundings on my older Navionics card shows ...
I can set the Shaded Depth at 0 and everything is white ... then click Shaded Depth to 1 - and it shades everything green up to 17ft ... then nothing changes again until I get up closer to 30 ...
You might get a better qualified answer from calling Navionics (instead of HB) and ask them why the Shaded Depth feature doesn't seem to work correctly in your HB unit ...
http://navionics.force.com/kb/pkb_mobile#
I've never been able to get a reasonable answer about Shaded Depth from any of the electronics forums I follow ...
Offline Surf N Turf
« Reply #2 on: October 24, 2016, 10:05:54 PM »
Thanks, I will contact Navionics.
Gregory
Offline Surf N Turf
« Reply #3 on: October 26, 2016, 08:30:33 PM »
Navionics Reply:
This problem that you are encountering happens to be  a plotter functionality.   It is the way that your unit is reading the card, the charting information has not changed by swapping it from one plotter to another.  You will need to continue you investigation through Humminbird.
For additional support, access Navionics online Help or Chat Now with a live agent.
Best regards,
Jennifer doCanto
Navionics Customer Service
« Reply #4 on: October 26, 2016, 09:21:13 PM »
Probably gonna get one of these things  ....
« Reply #5 on: October 27, 2016, 10:26:26 PM »
And that's exactly why we have never been able to get a reasonable answer as to why the Shaded Depth feature doesn't work as it seems it should ...
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #6 on: October 28, 2016, 06:47:32 PM »
Yes Sir ....
Last post January 31, 2016, 05:32:33 PM
Last post May 20, 2016, 10:56:27 AM
Last post June 29, 2016, 08:23:02 PM
Last post October 14, 2016, 09:18:15 PM
Last post January 07, 2017, 06:28:25 PM
Last post February 13, 2017, 09:04:17 AM
Last post February 22, 2017, 11:54:11 PM
Last post March 23, 2017, 09:48:49 PM
