Author Topic: 787c sonar problem  (Read 8461 times)
Offline larry e frazier
  • Unit(s): 998c 786ci2 787c2(2)
  • Software: ?
  • Accessories: Interlink between 787c2's &998/786ci2
787c sonar problem
« on: September 24, 2012, 07:53:00 AM »
my 787c sonar is not changing ranges andis not indicating the correct depth digitally(reads 1.6 ft all the time) but the sonar reads the graph very weakly. It is stuck on 0-10 ft  scale . I have tried to reset the defaults with no help. Could the transducer cause the sonar to do this? Gps and other features work fine. When I tried to increase the range manually the signal was very weak.
Any help would be appreciated. Larry
Re: 787c sonar problem
« Reply #1 on: September 26, 2012, 01:28:01 PM »
Yes a bad transducer can cause this Larry.  A bad installation can cause this too if the transducer is mounted inside-the-hull.
If you know someone else with a Humminbird unit you can test your 787c unit (or is it a 787c2 model?) on their Humminbird transducer to see if it works better or not.  All but the Humminbird models with “3D” or “DI” in their model names will work for this – even the Side Imaging models.
  • Software: ?
« Reply #2 on: September 27, 2012, 12:56:28 AM »
Thanks greg I have a new transducer I can swap and see if it corrects this. thanks larry
« Reply #3 on: September 27, 2012, 09:38:54 AM »
Let us know how it turns out Larry.
Last post August 14, 2012, 08:12:57 AM
Last post October 30, 2012, 06:02:10 PM
Last post April 16, 2013, 02:18:53 PM
Last post June 04, 2014, 06:46:02 AM
by zdriver
Last post May 05, 2016, 12:12:26 PM
by sienaazis
Last post May 20, 2016, 11:16:05 AM
Last post January 07, 2017, 06:28:25 PM
Last post May 25, 2017, 08:16:21 PM
by wolfgrw
