Author Topic: humminbird 859 ci hd reading problem  (Read 14071 times)
Offline jepik
  • Unit(s): 570 596 di 597 ci hd
« on: October 27, 2016, 11:56:35 PM »
it will lose depth in the numbers of feet but will show rts window readings all the time..example.. reading will show 3 ft but the rts window will show correctly at 7.5 ft...when at idle both will read correctly..thanks
Offline sfw1960
  • Bringer Of The 'Bird
Re: humminbird 859 ci hd reading problem
« Reply #1 on: October 28, 2016, 06:44:45 PM »
Maybe settings are all jacked up?
Try resetting defaults  - also if using 200/83KHz - try 200 KHz and turning sens. down a bit.
Offline jepik
« Reply #2 on: October 29, 2016, 12:34:28 AM »
thanks sfw 1960..I will give a try and restore defaults..
Offline sfw1960
« Reply #3 on: October 29, 2016, 01:06:30 AM »
Also SwitchFire clear if in under 20FOW may help....
Let us know~
Offline jepik
« Reply #4 on: November 04, 2016, 12:42:33 PM »
sfw1960..tried restoring defaults..switchfire to clear..under 20 ft. set at 200khz..did not get it.. although I think it help a little..seems not to lose the reading as much as it did..both still work at idle..rts window is a little more  diffcult to see now.. :'(
Offline sfw1960
« Reply #5 on: November 04, 2016, 02:16:41 PM »
Well if you registered it for Humminbird Select within the 1st yr., you can probably have them check or fix....
Last post June 23, 2011, 01:35:23 PM
Last post May 31, 2011, 04:52:22 PM
Last post November 21, 2012, 10:06:17 AM
Last post October 30, 2012, 06:02:10 PM
Last post June 04, 2014, 06:46:02 AM
by zdriver
Last post July 23, 2014, 03:58:06 PM
Last post October 25, 2015, 11:07:48 AM
by fishbone
Last post September 14, 2016, 12:35:37 AM
by anzin
