Author Topic: New 999 unit depth reading error; graph vs dig reading  (Read 28078 times)
Offline fishbone
« on: October 08, 2015, 09:04:21 AM »
Had my 999 SI HD out for the first time and saw some goofy readings on depth.
One example was in 8' of water where the scrolling graph read 8' correctly while the digital desplay (block on the left side) read 18'.
Most areas it was correct, but under 8' the digital was unreliable.
Any ideas?
Also, when I pressed the "mark" button, a saved message would pop up, but the chart was never actually marked. I may have something not 'set' or enabled. Not sure.
Thanks.
Sorry, I posted in the wrong spot and can't move it.
« Last Edit: October 08, 2015, 09:17:12 AM by fishbone »
2013 Stratos 189 VLO
E-Tec 150 HO 150hp, 6" JP
80# Fortrex, 2ea 8' Power Poles
HB 998cSI @ Console, HB 999HD SI @ Bow
Re: New 999 unit depth reading error; graph vs dig reading
« Reply #1 on: October 08, 2015, 09:36:10 PM »
Shallow water over hard bottoms sometimes creates these type of issues ...
You can try Switchfire Clear under the Sonar tab and maybe turn down Sensitivity just a little ...
If Screenshots is Enabled under the Accessories tab and there is no SD Card in the unit ... The unit will err on actually creating a waypoint ...
Either insert a SD Card or Disable Screenshots under the Accessories tab ...
Offline fishbone
« Reply #2 on: October 09, 2015, 07:18:12 AM »
The worse offending area did have a rocky bottom. Seemed strange one readout would be effected, but not another.
You are right again, I had no SD card in the unit. I'll correct that.
Thanks for the help.
« Reply #3 on: October 09, 2015, 02:43:32 PM »
Hard bottoms can allow the sound pulse to bounce more than once ... bottom reflection - surface reflection - back to bottom reflection - then to xducer ...("double echo" ...and sometimes "triple echo") ...
This sometimes confuses the unit as to which reflection the "actual bottom" really is ...
Switchfire Clear and reduced Sensitivity seems to be the best "workaround" for this specific scenario ...
« Last Edit: October 09, 2015, 02:46:19 PM by rnvinc »
Offline fishbone
« Reply #4 on: October 25, 2015, 11:07:48 AM »
[/quote]
It was already on Switchfire Clear. Which, or where, is the sensitivity that I can adjust down? Thanks
Last post June 26, 2010, 11:53:43 AM
by JeffA
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post June 11, 2010, 08:42:41 PM
by majflyboy
Last post October 31, 2012, 03:42:56 PM
Last post May 29, 2014, 08:41:20 AM
Last post July 28, 2014, 12:32:18 PM
Last post February 16, 2015, 12:26:34 PM
by jworks
Last post June 11, 2017, 08:12:16 PM
by fshndude
