Author Topic: Brightness level problem  (Read 14133 times)
Offline Bassman13579
  • Unit(s): 998c SI
« on: October 25, 2016, 07:59:27 PM »
I have a 998c si unit. When I go to the brightness level setting it is set on 10. I can set it to 9 & 8 and the brightness is about the same as on the 10 setting. The problem is when I lower the setting to 7 the screen goes almost completely dark. I fish a lot at nighttime and running down the lake with a bright screen blinds me from watching my tracking back to the launch.
Re: Brightness level problem
« Reply #1 on: October 26, 2016, 12:22:17 PM »
That is an older model.
Depending on how many hours you have on it, the screen may just be wearing out.
Everything wears out eventually.
It could also be a battery issue.
Fully charge your battery, and have it load tested.
If the battery is good, then I would call Humminbird Customer service, and see what they say.
They may charge you a small fee to look at the unit.
  • Unit(s): 998c SI
« Reply #2 on: October 26, 2016, 05:34:53 PM »
Unit even for its age has low hours on it. I purchased 3 new batteries this year but still have the problem. Unit brightness is very high. At nighttime it's blinding. Unit just want reduce level of brightness proportional to lowering the number. Thanks for help.
« Reply #3 on: October 26, 2016, 06:19:52 PM »
I recall that being an issue for a lot of people who night fished with the units that didn't have LED back lighting.  I don't remember if there were any software releases that affected it......What software version do you have?
« Reply #4 on: October 26, 2016, 07:34:46 PM »
You might try changing the background color (under one Power button press) ...
It probably won't help any map views ... but it may help the Sonar views not be as bright as the white background ...
You can call HB ... but their flat rate fee is pretty high for legacy units ...
http://www.humminbird.com/Category/Support/FAQ/RepairFees/
1-800-633-1468
  • Unit(s): 998c SI
« Reply #5 on: October 26, 2016, 08:58:01 PM »
Software version is 7.xx.
The screen I need to reduce brightness on is the navigation screen I think. The screen that shows the layout of River and has the routes I have took showing in blue.
« Reply #6 on: October 26, 2016, 09:12:56 PM »
You might also try the inverse color scheme for night.
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #7 on: October 26, 2016, 10:13:07 PM »
That and black background.
The LED backlights replaced the CCFL lighting because they are hard to dim down and keep the gas "excited" in the fluorescent lamp.
They require a high voltage to make the gas emit light and when you drop that voltage, the light dies out fast.
https://en.wikipedia.org/wiki/Cold_cathode
You're probably best off either paying the fee (probably would get a 999 {LED} to replace it) or just get a glare filter like a welding curtain uses to kill the amount of light.
« Reply #8 on: October 26, 2016, 10:31:46 PM »
Some also use a red filter over the unit at night .... red light doesn't affect night vision as bad as white light.
  • Unit(s): 998c SI
« Reply #9 on: October 27, 2016, 12:46:54 AM »
That's a great idea on filtering the light !!
Offline sfw1960
« Reply #10 on: October 27, 2016, 04:31:49 AM »
Look up "window tinting" , places like the big box home improvement stores carry the smoked type for windows.
I think Ace, Lowe's or Home depot get about $15 for a small roll.
Definitely beats the $500 repair price!   >:D
Last post May 19, 2010, 10:24:25 PM
by Moose1am
Last post June 19, 2010, 02:05:13 PM
by raricker
Last post March 09, 2011, 11:47:15 PM
by muskyhunter
Last post March 27, 2012, 11:55:04 AM
Last post April 04, 2013, 10:52:41 AM
by Jim Jack
Last post April 10, 2013, 08:38:07 PM
Last post May 21, 2013, 09:08:57 PM
by Midtin
Last post August 31, 2023, 09:05:29 PM
