Author Topic: Transducer level?  (Read 10161 times)
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Transducer level?
« on: March 09, 2012, 08:08:02 PM »
How can I insure that my side-scan transducer for my 1197(console) and 998(trolling-motor) are level in use?
Can you not observe side-scan image when passing near bridge supports?
Re: Transducer level?
« Reply #1 on: March 10, 2012, 10:43:34 AM »
If you have a water line on the boat you can during a trailer of the boat level the boat using the water line and then check the transducer level..
Unless it is way off level then it is a bit hard to make that determination on the water..
Front to back is different than port to starboard.
Front to back may show bottom readings off kilter or induced cavitation clutter..
Port to starboard is a bit different and can be sometimes the sources of surface clutter on one side of the SI.
« Reply #2 on: March 26, 2012, 05:43:04 PM »
You can usually get real close by observing the shadow angle of a straight pole or bridge piling.  If the shadow does not stick straight out at a 90 degree angle than the transducer is tilted too far up or too far down.
« Reply #3 on: March 26, 2012, 05:57:04 PM »
Never noticed the shadow before.  Will have to check on this.
Another way is compare left and right displays. If there is a tilt one side will be showing clearer targets than the other..
Offline LittleGazoo
  • Software: 3.640
« Reply #4 on: March 27, 2012, 11:12:59 AM »
Thanks Greg,
A little more help needed.
A 30-40 foot deep bridge piling should be slightly tilted toward the top as the sonar reflection will be returning from a closer range?  Seems I read this long time back, but never found URL again.
If piling is tilted indicating transducer is a bow-tilt or stern-tilt.  We should be able to tell tilt direction from the sonar display?   Would a bow-tilt sonar display a right-lean or a left-lean?
« Reply #5 on: March 27, 2012, 11:55:04 AM »
LG,
A perfectly vertical bridge piling or a pole should display a perfectly horizontal shadow in the Si sonar.
If the back end Si transducer was angled downwards (pointing forwards), than the shadow will be skewed towards the top of the display because the bottom part of the Si sonar beam will contact the piling first and the resulting shadow will angle towards the top of the display (new Si sonar data).
If the back end Si transducer was angled upwards (pointing backwards), than the Opposite will happen and the shadow from the piling will be angled towards bottom of the Si display window.
Attached is a file I did on Si transducer twist (forgot I had this).
Last post June 19, 2010, 02:05:13 PM
by raricker
Last post March 29, 2012, 10:02:55 AM
Last post May 17, 2012, 08:23:40 AM
by generalpatton71
Last post April 04, 2013, 10:52:41 AM
by Jim Jack
Last post June 07, 2013, 11:38:06 PM
by thunderbucket
Last post January 16, 2014, 11:01:35 PM
by 97Aero
Last post June 16, 2014, 06:12:45 PM
by Bradaus1
Last post July 23, 2014, 08:08:17 AM
by squam
