Author Topic: Screen brightness..  (Read 16347 times)
Offline JeffA
  • Unit(s): 898c SI
  • Software: 4.880
Screen brightness..
« on: April 26, 2010, 02:13:16 PM »
the screen on my 898 seems a bit "dim" more so in the SI screens, the brightness is all the way up too, if i look at it from an angle, the screen almost looks black....is this normal????
 "if your going to mess with the kings queens, you better watch your ace, jack!"..
Re: Screen brightness..
« Reply #1 on: April 26, 2010, 02:26:04 PM »
Jeff, can you post a picture?
chuck
« Reply #2 on: April 26, 2010, 05:50:49 PM »
Jeff, another thought.   Is this on all the screens or just the sonar?
thanks, Chuck
Offline JeffA
  • Unit(s): 898c SI
  • Software: 4.880
« Reply #3 on: April 26, 2010, 06:52:41 PM »
cant get a pic right now, its seems more on the main screen when the unit first powers on, then on the SI screens, the brightness is all the way up
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #4 on: April 26, 2010, 09:28:46 PM »
JeffA:
My 898C SI does the same thing.  they need to make the SI and DI screens brighter.  And mine is brighter when the sensitivity is set up to 20.  On Auto Sensitivity the screen is too dark most of the time.
And I am trying all the different screen colors too.  They all seem to be too dark.
Regards,
Moose1am
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« Reply #5 on: April 26, 2010, 09:32:34 PM »
I will have to say someone was reading my mind.  I have mine out for the first real test today and noticed the exact same thing.  My screen is kinda on the dark side.  I will say though the green screen works best for a better picture.  I tried everything myself. I also noticed that the deeper the water...the better the pic.  It seems this really is on the Side Image and not the other screens.
Offline jimf
  • Unit(s): 997ci si
« Reply #6 on: April 27, 2010, 09:40:33 AM »
I wrote a post on screen brightest on the 997 link. Read it. it might help.
Offline JeffA
  • Unit(s): 898c SI
  • Software: 4.880
« Reply #7 on: April 27, 2010, 04:54:18 PM »
i sent an Email to Humminbird about it, see what they say.
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #8 on: May 18, 2010, 08:20:18 PM »
One thing that we all might check out is the electrical connections between the battery and the units control head.  Make sure that all electrical connections are nice and tight and that you use a 3 amp in-line fuse for the hot wire.  That's the red one for those that are not familiar with the color coding on the wires.  Black is the ground or negative DC wire.
One question for Humminbird_Greg:  Does the length of the wires and the size of the wires make a difference?  I guess that no more than 3 amps is allowed to flow though these wires.  And the power plugs wires look like 18 gage.   They are not very heavy duty wires for sure.   So I used 18 gage wire to extend these power connection wires to reach my battery.
Regards,
Moose1am
Wayne P.
  • Guest
« Reply #9 on: May 18, 2010, 08:48:42 PM »
Moose, yes the wire size does matter if you extend them very much. With DC current, the total length of the positive and negative wires determines the amount of voltage loss.
« Reply #10 on: May 19, 2010, 09:24:17 AM »
Another consideration is,  if the wire is a shared supply.  That goes for the negative reutrn wire also.
We use 12 guage stranded or 14 guage solid copper.
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #11 on: May 19, 2010, 10:24:25 PM »
I can run some heavier wire from the battery to the control heads power connection wires.  With the connectors I am using that will be an easy fix.  Just need to get around to working on this.
Regards,
Moose1am
Last post April 08, 2010, 10:24:15 AM
Last post June 02, 2010, 07:37:31 PM
by dpirila
Last post March 09, 2011, 11:47:15 PM
by muskyhunter
Last post April 10, 2013, 08:38:07 PM
Last post May 21, 2013, 09:08:57 PM
by Midtin
Last post October 27, 2016, 04:31:49 AM
Last post August 31, 2023, 09:05:29 PM
