Author Topic: Humviewer and Helix Sonar File incompatibility  (Read 19326 times)
Offline mako9man2
  • Unit(s): 999ci HD SI
« on: February 11, 2017, 08:04:43 AM »
I have a Helix 12si KVD that I use to make Sonar recordings.  I can load these files  (R00025.DAT for instance) into HUMVIEWER following the instructions on the LakeImages training video).  I can edit these original files in Humviewer and create new files (R0025A.DAT for instance) which might be short segments of a particular track.  BUT  I can not load these edited files (R0025A.DAT) back into HUMVIEWER.
Is anyone else using Humviewer to edit HELIX sonar data and have you experienced any problems?
Re: Humviewer and Helix Sonar File incompatibility
« Reply #1 on: February 12, 2017, 10:04:32 PM »
I did some experimenting with recordings from my 1197 ...
On my 1st attempt to make a sub-recording, I clicked the start point and end point of the sub-recording in the SI image pane ... This sub-recording failed to reload into Humviewer like you described ...
I then closed Humviewer and deleted the sub-recording files created so I could start from scratch again ...
On my 2nd attempt to make a sub-recording, I clicked the start point and end point of the sub-recording in the 2d image pane ... This sub-recording loaded successfully into Humviewer  ...
Now with every attempt to make a sub-recording, I can click the start point and end point of the sub-recording in either image pane (2d or SI) and the sub-recording will successfully load into Humviewer ...
Offline mako9man2
« Reply #2 on: February 13, 2017, 02:21:00 AM »
Thanks rnvinc.
I tried your method with no success.  However my issue is not as bad as it seemed at first.  While I can't open the edited file with Humviewer I can open it in Autochart Pro and create a map which was my ultimate goal.
« Reply #3 on: February 13, 2017, 09:04:17 AM »
There may something different with the HELIX recording vs my 1197 recording ...although I don't know what it would be ...
Hopefully someone with a HELIX can test this and post results here for you ...
Last post March 15, 2010, 12:29:53 PM
Last post March 20, 2010, 05:37:59 PM
by twobearlake
Last post June 01, 2010, 01:57:41 AM
by muskyhunter
Last post August 21, 2012, 11:30:17 PM
by LLCC
Last post February 22, 2013, 07:02:22 AM
by TroyBoy30
Last post May 03, 2014, 12:11:57 PM
by Pipe Rat
Last post April 09, 2016, 09:42:21 AM
by nwkramer
Last post May 27, 2020, 04:41:34 PM
by kevlar119
