Author Topic: Transducer question  (Read 8119 times)
Offline jjbch
Transducer question
« on: March 30, 2011, 07:58:45 PM »
What is the difference with the XAP 9 20 and the XP  9 20 other than the angle.
Will the angled transducer work better when glassing in and not on a true flat surface.  Also will the temp sensor in the XP 9 20T override the temp on the transom mounted  XNT-9-SI-180-T. Thanks for the help
Re: Transducer question
« Reply #1 on: March 31, 2011, 02:41:35 PM »
The only difference between the XP-9-20 and XAP-9-20 is the angle on the bottom of the transducer.
Whether the XAP will work better or not on an angled hull would depend on the angle of the hull.  The XAP-9-20 was meant for hulls that have a deadrise angle of 14 degrees or more.
The temperature sensor in the XP-9-20-T will not override anything.  If you have this and the XNT-9-Si-180-T transducer both connected to an AS-Si-DB-Y cable than the temperature will always come from the XNT-9-Si-180-T transducer as there is no electrical connection made to the temperate sensor in the XP-9-20-T transducer when using this cable.
If you connect the XP-9-20-T transducer and the XNT-9-Si-180-T transducer to a TS2-W Transducer Switch; than whichever transducer you have the switch set to will determine which temperature sensor the unit will use.
Offline jjbch
« Reply #2 on: March 31, 2011, 02:49:23 PM »
Greg,
Thanks as always
Last post October 20, 2009, 09:00:54 AM
Last post March 25, 2010, 12:14:33 PM
by jclark
Last post May 06, 2010, 04:02:06 AM
Last post August 19, 2010, 11:49:07 PM
by ericd
Last post September 11, 2010, 10:10:15 AM
Last post February 23, 2011, 05:00:52 PM
Last post April 01, 2011, 02:37:57 PM
by LoonASea
Last post October 16, 2011, 10:56:58 PM
by Roddy
