Author Topic: Transducer Model Question?  (Read 9700 times)
Offline jnaron_ngc
  • Unit(s): 797c2
« on: February 20, 2011, 10:21:34 AM »
Hi Ya'll
After digging around it seems that transducers are mentioned alot as a possible reason for no fish on screen.
Can anyone tell me what transducer I should use for optimum performance with the latest firmware update? I am wondering if my original transducer (Dual Beam I Think)  that came with the unit in 2007 might not be up to snuff. Although I can see SI images very well, lots of logs in most of  my lakes, I never see any obvious fish images, like I see on the images shared by forum members. I fish one particlar lake that has no bottom structure at all, and has huge schools of crappie, but my unit never sees them, while my Eagle sonar that came on my Pro Crappie 175 sees tons of fish. Please help this is killing me!!
« Last Edit: February 20, 2011, 10:37:11 AM by jnaron_ngc »
Offline jnaron_ngc
  • Unit(s): 797c2
Re: Transducer Model Question?
« Reply #1 on: February 21, 2011, 06:17:03 PM »
41 views and no help?
« Reply #2 on: February 21, 2011, 10:49:36 PM »
jnaron,
The transducer that originally came with your 797 should be a compact SI transdcuer.  It is perfectly capably of showing fish in the SI/DI mode.
What may help is to post some snapshots from your unit of some structure or suspected fish.  It will show us what you are seeing and maybe help us give you some ideas on how to get those fish to show up.
Here is some good reading.
http://forums.sideimagingsoft.com/index.php?topic=333.0
Offline jnaron_ngc
  • Unit(s): 797c2
« Reply #3 on: February 23, 2011, 11:17:35 AM »
Thanks Robert I will take some snapshots and post here.
« Reply #4 on: February 23, 2011, 05:00:52 PM »
Make sure that all other sonar are off when you make these snapshots.
I would also reset all menus back to the factory settings and than set the Beam Select menu to the 200/83 setting and make sure that SwitchFire is set to the Max Mode.
Last post October 20, 2009, 09:00:54 AM
Last post March 25, 2010, 12:14:33 PM
by jclark
Last post May 06, 2010, 04:02:06 AM
Last post August 19, 2010, 11:49:07 PM
by ericd
Last post September 11, 2010, 10:10:15 AM
Last post November 21, 2010, 06:15:00 PM
by dizzyfish
Last post April 15, 2012, 02:12:50 PM
by bbordeau
Last post October 17, 2016, 08:28:48 AM
