Author Topic: Mounting transducer beside existing transducer  (Read 14238 times)
Offline Mukwah
  • Unit(s): Helix 7
  • Software: N/A
« on: September 26, 2016, 04:14:54 PM »
I've just acquired an Helix 7 Humminbird SI. I have an existing Garmin GPS. I was hoping to be able to position it for use of forward fishing person. My question is can I put the transducer beside the existing one and not experience any interference. I understand that I will need to ensure that the SI transducer has clear sight lines left and right.  The Garmin transducer would be placed to right and above line of sight. I will be using a mounting plate for the transducers.
Re: Mounting transducer beside existing transducer
« Reply #1 on: September 26, 2016, 04:18:08 PM »
If the units are operating on the same frequencies you will get crosstalk interference.
Offline Mukwah
  • Unit(s): Helix 7
  • Software: N/A
« Reply #2 on: September 27, 2016, 12:08:59 PM »
Thanks Bob, I was hoping to avoid putting a transducer on the trolling motor, I had a clutzy friend break a transducer wire previously while putting the motor into the water. The frequencies that you mention are they the ones that you set for down imaging? I wasn't planning on using garmin for gps applications. I could even remove the chip from the garmin.
« Reply #3 on: September 27, 2016, 12:23:16 PM »
GPS is no concern since it is only a receiver .... It is the 200 and 455 Khz sonar frequencies that will be a problem if both units are using them..... I don't know what the frequency selection options are on your Garmin.
Offline Mukwah
  • Unit(s): Helix 7
  • Software: N/A
« Reply #4 on: September 27, 2016, 03:40:27 PM »
Thanks again Bob, that is what I was hoping I can ensure that the frequencies are different.
by jgcox6
Last post February 13, 2013, 09:50:14 AM
by hgv
Last post July 09, 2013, 01:22:25 PM
Last post February 21, 2015, 11:14:04 PM
Last post May 13, 2015, 11:43:05 PM
Last post June 01, 2016, 11:05:29 AM
by tellicorick
Last post August 23, 2016, 10:05:55 AM
