Author Topic: Transducer mounting  (Read 8755 times)
Offline hgv
  • Unit(s): 798ci HD SI
  • Software: 6.x
Transducer mounting
« on: February 20, 2015, 06:41:24 PM »
Anyone have any experience mounting a transducer on a tunnel hull (see picture)? Star marks the purposed location. Wondering though if the live well intakes would interfere with side imaging.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Transducer mounting
« Reply #1 on: February 20, 2015, 07:46:33 PM »
intakes will block some signal. I would be more concerned about the flow through the tunnel being turbulent at low speeds. At on plane speeds the transducer will be high and dry.
« Reply #2 on: February 20, 2015, 10:57:59 PM »
Does the xducer mounted to the left function correctly in its location ...??
Offline hgv
  • Software: 6.x
« Reply #3 on: February 21, 2015, 10:06:44 AM »
Yes it does I mounted there originally due to the only way to get in the boat was a small step on the other side and I was afraid someone would mistake it for a step and break it off or worse cut a foot. Plan on moving now that I have added a ladder, transducer needs to be higher
« Reply #4 on: February 21, 2015, 11:14:04 PM »
As bobcoy mentioned ... The intakes will block some of the signal with the xducer mounted above the intakes ...
You could add a mounting board to your position with the star to possibly get the xducer to set back far enough for the beams to miss the intakes ...
I would guess your possible location on the transom will have the xducer completely out of the water when on plane ...
You can bypass this obstacle by adding a XP 9 20  in the bilge with the AS SIDB Y cable for allowing the 2d depth readings to come from the bilge mounted XP 9 20 ...
« Last Edit: February 21, 2015, 11:15:44 PM by rnvinc »
Last post March 06, 2011, 08:22:58 AM
by troutfanatic
Last post April 30, 2011, 07:02:34 PM
by djhoffman
by jgcox6
Last post March 24, 2016, 09:48:24 AM
by ctsalt12
Last post June 01, 2016, 11:05:29 AM
by tellicorick
Last post August 23, 2016, 10:05:55 AM
Last post September 27, 2016, 03:40:27 PM
by Mukwah
