Author Topic: 798 transducer mounting  (Read 11653 times)
Offline hgv
  • Unit(s): 798ci HD SI
  • Software: 6.x
« on: February 12, 2013, 02:59:53 PM »
Here is the existing location of the transducer. Works well here but thinking about lowering it the next step to get higher spped operation of the  transducer. Any advice on mounting it between the drain holes for the livewells?
X marks the new spot
Offline Speedtroller
  • Unit(s): 798ci SI
  • Software: 5.840 6.300
Re: 798 transducer mounting
« Reply #1 on: February 12, 2013, 04:15:01 PM »
You most likely will not get readings when on plane. Unless you put it on the bottom step. You may want to consider going with a shoot thru hull 2d transducer and a y cable.
Fishing, a jerk on one end, waiting for a jerk on the other end !!!
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #2 on: February 12, 2013, 07:25:19 PM »
Just make sure the trailer doesn't get in the way if you're moving it lower.
« Reply #3 on: February 13, 2013, 08:48:36 AM »
+1
XP-9-20 inside-the-hull transducer plus an AS-Si-DB-Y transducer splitter cable will get you all fixed up.
Offline hgv
  • Software: 6.x
« Reply #4 on: February 13, 2013, 09:50:14 AM »
i have already added the thru hull ........  http://forums.sideimagingsoft.com/index.php?topic=5015.0
Just playing around with the idea of moving the transom mounted transducer lower to get better side imaging a speed
by jgcox6
Last post December 30, 2013, 10:52:41 PM
Last post January 30, 2014, 01:29:19 PM
Last post November 25, 2014, 05:13:59 AM
by jabsy
Last post January 21, 2015, 12:08:28 AM
Last post August 23, 2016, 10:05:55 AM
Last post September 27, 2016, 03:40:27 PM
by Mukwah
