Author Topic: What does SI interference look like?  (Read 6187 times)
Offline mike fish
« on: September 15, 2016, 06:17:37 PM »
 If I'm running 2-999's, 1 TD port, 1 TD starboard at the same time I'd get interference? Correct?  What would this look like on SI screen?  Reason I'm asking is I was trying to do some comparison the other day and was having an awful time. Thanks
Re: What does SI interference look like?
« Reply #1 on: September 15, 2016, 09:28:47 PM »
Interference in the SI looks like horizontal lines ...
Interference in the 2d looks like vertical lines ... (Digital depth will also usually be erratic) ...
Having 2 SI xducers at the same height can also create physical blockage of the SI beam on that side facing the opposite xducer ...
« Reply #2 on: September 16, 2016, 09:03:09 AM »
Since you have 2 transducers mounted, why don't you connect them to 1 unit only using a Y cable.  Each transducer would only be using the SI element for that side of the boat.....and then you can share the imaging between the units with Ethernet....You would have no crosstalk concern and SI on both units.
Turn off the sonar on the unit with no transducers physically connected.
Offline mike fish
« Reply #3 on: September 16, 2016, 10:28:31 PM »
That's what I was seeing on 2D and it just dawned on me the other morning it was interference . The SI was very grainy and the left TD was hot on the left side.
What I was trying to do was compare the different software side by side between the 2 units.
Not planing on running 2 SI ducers at this time.  The 2nd ducer was from my other unit. Thanks
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post December 11, 2012, 07:22:15 AM
Last post February 08, 2013, 02:12:20 PM
by Ken L
Last post April 29, 2013, 06:31:32 PM
by Lsobo21
Last post May 13, 2013, 11:20:11 AM
Last post April 10, 2014, 12:49:21 PM
Last post November 04, 2014, 12:36:32 PM
Last post July 27, 2015, 09:50:47 AM
