Author Topic: TM interference  (Read 12888 times)
Offline Perch Jerker
  • Unit(s): 1198
  • Software: 6.490
  • Accessories: transducer select switch
TM interference
« on: January 26, 2013, 11:18:32 AM »
lots of crappie, all had lock jaw! also a little TM interference, which        I corrected by twisting the power leads from battery to unit.
Offline reddog
    • My pictures
  • Unit(s): 2)997 C SI, 788CI, 787C2, 1197 1198
  • Accessories: Ipilot Link
Re: TM interference
« Reply #1 on: January 26, 2013, 03:11:30 PM »
Can you explain this a little more? You twisted the positive and negative leads from the battery to the trolling motor?
Hate to see her go, but love to watch her leave.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: TM interference
« Reply #2 on: January 26, 2013, 03:30:13 PM »
I think he meant twisted pair. You and twist them together with a cordless drill by holding one end and "drilling" the other end until you get a good twist.
 ..kind of like this:
« Last Edit: January 26, 2013, 03:33:00 PM by LocDown »
  • Unit(s): 1198
  • Software: 6.490
Re: TM interference
« Reply #3 on: January 26, 2013, 08:05:43 PM »
Yes Red Dog ,chuck up the power wires in a cordless drill with the opposite end secured, twist until snug. It will sometimes do wonders for interference.  Ray
Re: TM interference
« Reply #4 on: January 26, 2013, 08:43:17 PM »
Yes, twisting the wires together changes the electrical characteristics of the wire and will significantly reduce interference.  There are "chokes" or ferrite coils that can be put around the wires near the unit that will help also.
Offline reddog
    • My pictures
Re: TM interference
« Reply #5 on: January 26, 2013, 09:44:14 PM »
I have the ferrite ring on my terrova. Just hadn't heard of here twisted wire trick. simple enough, thanks.
Re: TM interference
« Reply #6 on: January 26, 2013, 10:36:56 PM »
Start the twisted wire pair with about twice the length of run needed because the twisted pair becomes shorter the more it is twisted...
Offline Ken L
  • Unit(s): 598C HD DI-SI
  • Software: 6.460
  • Accessories: none
Re: TM interference
« Reply #7 on: February 08, 2013, 02:12:20 PM »
You may or may not want to do this but if you strip the outer covering off the power cable you can then separate the leads. If you then clamp the plug in place you can wrap the wires around each other hand over hand and they won't coil up. This will shorten the length but only by a fraction of that if you just twist the whole thing in a drill. Another way to do this would be to fasten one lead in place and spin the other with a drill. If you then slowly bring both leads together they will wrap around each other the same way with no coiling unless you overdo it with the drill. You could then wrap it in electrical tape or find another way to protect it. There could be some installations where this might be a better solution.  Long before smartphones and digital everything telephone calls were always transmitted over pairs of wires and they had to be twisted this way or the call would have been unintelligible.
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post March 08, 2011, 07:00:52 PM
by Sigler
Last post April 24, 2011, 11:05:28 AM
by FlatsFokker
Last post June 27, 2011, 01:53:40 PM
Last post July 15, 2011, 09:15:58 PM
by Double Digit
Last post October 30, 2011, 08:53:59 AM
by Mark997
Last post December 11, 2012, 07:22:15 AM
Last post April 09, 2013, 01:12:06 PM
