Author Topic: Combining recordings from 3 different units  (Read 7785 times)
Offline saoulons
  • Unit(s): 1199 HDSI
  • Accessories: Network, IPilot-Link, Autochart, 360 Img
« on: July 10, 2016, 03:21:29 PM »
Is it possible to combine recordings from 3 different units? These units have different X, Y, Z settings wrt to GPS positioning against the transducer. It looks like the Autochart setting is at the map level, not at the individual recording level.
Is there a way to set the X, Y, Z variables for each recording?
Thanks!
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
Re: Combining recordings from 3 different units
« Reply #1 on: July 11, 2016, 08:50:54 AM »
if each unit has their own settigns cone agngle ... then there is no way you can setup AutoChart PC to run on 3 settings seperatly
it's a one shot setup which can be modify of course on demand from the general settings
Offline saoulons
« Reply #2 on: July 11, 2016, 10:34:46 AM »
Thank you. Do you know if changing the X, Y, Z settings right before importing the data would work? Would have to change it every time I import from a different unit but this could do the trick.
One related question, can I delete the sonar data after importing? If so, then maybe what I'm asking about above would work. Thanks!
Offline Beaulieu80
  • Software: 7.68
« Reply #3 on: July 11, 2016, 11:59:55 AM »
you change those yes on the import setting this will appy the settings on the imported files yes
Offline saoulons
« Reply #4 on: July 17, 2016, 10:24:42 AM »
Thanks. I also noticed that there is an option in the File Menu called "Import Setting" and you can select "Ask for X/Y/Z/Tilt/Latency correction" so that it asks you every time. This validates the point that you can combine data from 3 different units.
by garinis33
Last post May 22, 2012, 05:13:20 PM
Last post June 24, 2010, 05:52:52 PM
by pig75
Last post January 30, 2012, 08:15:19 PM
Last post April 08, 2012, 05:18:05 PM
by RickT
Last post April 04, 2013, 10:48:58 AM
Last post March 22, 2014, 03:15:22 AM
Last post March 25, 2014, 11:33:54 AM
