Author Topic: Domestic units successfully updated but international units don't  (Read 22093 times)
Offline garinis33
  • Unit(s): 997
  • Software: 5.3
Hi.I updated successfully two domestic 997c models with the new 4.7 software but i failed to update two 1197c international models.I used the same storage card for all of them.The 1197 models don't even read the card when inserted in the slot.Any advice?
bobcoy
  • Guest
Re: Domestic units successfully updated but international units don't
« Reply #1 on: January 23, 2010, 04:46:30 PM »
I am not sure about international units but I have an 1197 and it will not recognize MMC cards. only SD. If you are using an SD ignore this message. Bob
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: January 24, 2010, 12:48:51 AM »
That`s strange indeed. I thought the update files are the same on both versions (international and domestic).
Regards / Harry
YES,......
WE SCAN!
IRC Kevin
  • Guest
« Reply #3 on: January 24, 2010, 06:39:18 AM »
I presume that you have deleted the 997 update off the card before trying to load the 1197 update? If you haven't it's possible that it's trying to load the wrong one. (I presume the updates are different for different machines, as they were released at different times)
« Reply #4 on: January 24, 2010, 01:18:10 PM »
Each software update is unique to the specific unit.  If you downloaded the 997 update it would not be the same as the 1997 update.  Make sure you have deleted the 997 update or use another sd card all together for the 1197 update.
Offline garinis33
  • Unit(s): 997
  • Software: 5.3
« Reply #5 on: January 25, 2010, 06:45:45 AM »
Hi again.Thank you all for your replies.I deleted the 997 update from the SD card and i loaded the 1197 update.Both 1197 units updated successfully with the new 4.7 software.
Last post August 21, 2018, 11:36:30 AM
Last post March 16, 2010, 02:19:58 PM
by stillbear
Last post October 26, 2009, 04:39:33 PM
Last post October 22, 2009, 01:55:31 PM
Last post August 12, 2010, 03:31:15 PM
by Wayne P.
Last post June 21, 2012, 09:12:07 AM
Last post December 27, 2013, 03:16:33 PM
by RuffWood
