Author Topic: 999 transducer depth problems  (Read 9028 times)
Offline mrbago
« on: June 05, 2016, 03:04:25 AM »
Hey all. I'm having some issues with my depth reading. Well I'll write what has happen ended as of yet. Hoping to get some resolutions.
Bought a new boat. Has a 999 at console and 998 at the trolling motor.
Original owner had the 998 at the console but upgraded and moved it to the front and replaced console to 999.
999 is still running off the original si ducer for the 998.
Problem I'm having is the depth on the console is constantly displaying at 2fow. Moved the 999 up front and had depth reading off that ducer. Have yet to try the 998 on console as I didn't know one of the plugs were different.
Unit was reading depth just fine before the boat was sold to me. but what I think happened is when previous owner was deleting waypoints, he also reset units back to factory settings. Unsure if that has anything to do with it.
Has anyone had any symptoms of a bad transducer where it would not read depth at all? Hoping for an easy fix before trying and buying a new transducer. Thanks.
Re: 999 transducer depth problems
« Reply #1 on: June 05, 2016, 11:18:04 PM »
If there is a shoot thru xducer and the AS SIDB Y cable ... Disconnect the AS SIDB Y cable from the unit and plug the HDSI directly into the head unit ...
If the issue is fixed = the shoot thru xducer has come loose or failed ... Or the AS SIDB Y cable is bad ...
If the issue is still present ... Test the other unit on the console xducer Setup ...
Last post May 04, 2010, 08:57:45 PM
Last post July 05, 2011, 03:43:22 PM
by Chad711
Last post July 01, 2011, 09:42:48 AM
by mchunter
Last post August 04, 2011, 10:48:09 AM
Last post April 28, 2013, 11:22:55 AM
by albe
Last post May 07, 2014, 10:28:16 AM
Last post June 06, 2015, 06:18:08 PM
Last post June 06, 2016, 11:50:49 PM
