Author Topic: 899 SI depth problems  (Read 8608 times)
Offline kelvin
  • Unit(s): Helix 7
  • Software: none
  • Accessories: none
« on: June 05, 2016, 02:00:49 PM »
I have a new 899 SI , the depth will not always read correctly, in 8' of water it may bounce to 19' then back down after a few minutes. Any help would be greatly appreciated!
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: 899 SI depth problems
« Reply #1 on: June 05, 2016, 11:08:08 PM »
The first thing I would check is your sensitivity setting.  If it is to high, this can happen.  Try lowering it to see if this helps. If you were in 8' of water with a soft bottom and went over a hard area,
that 19' could be a second echo.
           Mike
« Reply #2 on: June 05, 2016, 11:14:06 PM »
Switchfire Clear can help with erratic shallow water depth issues also ...
Offline kelvin
  • Unit(s): Helix 7
  • Software: none
  • Accessories: none
« Reply #3 on: June 06, 2016, 02:44:21 PM »
I will try both of these to see if they help. I think my sensitivity was around 11, I was looking at SI and this is where it was clearest at.
I will also see if I was on clear mode.
Thanks for the suggestions, any other help appreciated!
« Reply #4 on: June 06, 2016, 11:50:49 PM »
It may be important to mention that Sensitivity will need to be different for SI - 2d (and DI) ...
This is mainly because of the difference in the distinctive Sonar shapes ...and how much gain each individual Sonar pulse needs to get adequate reflection data ...
Last post May 04, 2010, 08:57:45 PM
Last post July 05, 2011, 03:43:22 PM
by Chad711
Last post July 01, 2011, 09:42:48 AM
by mchunter
Last post August 04, 2011, 10:48:09 AM
Last post August 19, 2011, 01:50:51 AM
Last post April 28, 2013, 11:22:55 AM
by albe
Last post May 07, 2014, 10:28:16 AM
Last post June 05, 2016, 11:18:04 PM
